hey guys, my car is back up for sale! its time for a change and have my eyes keen on another car, but if you have something other than a skyline for trade, hit me up and i just might budge. cash adjustment mine or yours, whatever.
its an r32 gtst with 140k on the clock and 110k on the engine. engine was swapped over as i spun a bearing on the old one. i WAS looking for 14500 bout 2months ago (feb), but have just put in hks hipermax fronts with tein rear coilovers, mechanical 2way LSD and just paid 1years rego. I also have a brand new Vertex front bar not fitted as i like my 'drift scarred' vertex fronty LOL.
so with that aside, im looking for $15,500 $15,000.
Engine and Driveline mods
ATP T3/T4 hiflow
Nismo 555cc injectors and resistor pack
z32 air flow metre
Dr. Drift remapped ECU
Turbotech boost controller
Denso Hi-flow fuel pump rated at 500HP
Exedy heavy duty clutch and flywheel machined
Replaced clutch thrust bearing
genuine C’s short shift kit
Stainless steel intake pipe (turbo to pod)
HKS pod filter
3' Pacer Maker Front pipe
3.5" cat-back exhaust to a 4.5" Cannon tip
3" High flow cat
exhaust control valve (lever you pull to make ur car 10dB quieter. good for the police)
custom in-cabin fan switch (turns on a 2nd fan for the engine, for those hot days in traffic)
Exterior
Full Vertex kit
Front Mount Intercooler 600x300x80
16†2-piece Japanese Modena lightweight rims + r33 black rims for spares
Rear wing removed
Clear indicator lights
Mtec HID look bulbs
Front eyelids
Suspension and Handling
Mechanical 2way LSD
HKS Hipermax front coilovers – fully adjustable
Tein rear coilovers – fully adjustable
Tomei hicas lock
Whiteline front strut brace
4 brand new tyres
Interior
Nismo front floor mats
Genuine rear Skyline floor mats
Pro Con Boost, Water and oil Gauges
Pioneer Speakers and JVC head unit
Factory Sunroof
Tinted Windows
Turbo Timer
Extras
new unpainted vertex front bar
Raizon volt stabilizer kit
Replaced all coil packs, thermostat, water pump, ignition module and alternator
Full 100k Service done
New radiator
New radiator hoses
New battery
Paging alarm system
Stock muffler (for epa)
exhaust manifold gasket
stock suspension
spare alternator
stock injectors
PM me, call Miguel on 0432315388 if your interested, or email me at [email protected]
https://www.sau.com.au/forums/topic/155710-r32-gtst-melb/
yehp ill let you know bud. not interested in interstate cars 'cause i really cant be bothered doing all the interstate rego changeover and that kinda stuff at the moment
https://www.sau.com.au/forums/topic/155710-r32-gtst-melb/#findComment-2899453
  • 2 months later...
nah no dyno graph, but made 175rwkw on 12psi at dr.drift. was previously running at 15psi with a wolf 3d and made 198rwkw, but i wasnt happy with the ecu. current power band feels much better and suits my style of driving.
https://www.sau.com.au/forums/topic/155710-r32-gtst-melb/#findComment-3064267
swap a r33 series 1.5 type m let me know
https://www.sau.com.au/forums/topic/155710-r32-gtst-melb/#findComment-3064834
going to miss it being parked in the garage :) , but all good things must come to an end. hopefully to make way for a fat assed s14 im looking to buy. c'mon people!
https://www.sau.com.au/forums/topic/155710-r32-gtst-melb/#findComment-3070235
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
