Would anyone be able to tell me if these measurments would fit my car? Im planning on buying rims tommorow but because my car is at the machanics i have no car to test on.
Size is:
17"x9 with +18offset
Im just wondering if theres any modifications needed to fit these?
Would it clear calipers?
Would it rub gaurds?
Im also running on cusco adjustable suspensions if that helps!
Thanks guys!
https://www.sau.com.au/forums/topic/155713-17x9-on-a-r33-s2-with-18-offset/
  • 4 weeks later...
Hrrmmmm your right it does stick out of gaurds roughly 3 cms. With my coilovers lowered it will hit the gaurds. And the insurance company said that itll be illegal to have the whell sticking out of gaurds.
Anyone have any ideas what i should do?
I was planning on having my gaurds rolled out and raise the suspension.
Would that make it more legal, or should i sell out the rims?
Edited by cjlancer
You will deff need to roll the guards dude.
Those offsets are for gtrs which have a more pumped guards than gtsts..
Sell the rims,
And get offsets at min or 30 for a gtsts..
30 front, you might just have to roll it a little..
Anything below 30 offset, will just hit the guards easily.. plus it will look gay anyways.. lol
I reckon for 17inch rims, 32 offset front, 35-37 offset rear is best combination..
Plus you already have 9inch wide rim.. It will look phat!!
Btw is that 17*9 all the way around?
Im not to sure if the fronts will fit then.. AS in, it might touch your coilovers..
In short, those rims are for GTR's!!
Edited by siddr20
Ive got some stretched tyres at the front already with 235s, rears are 265. But it causes alot of camber wear.
It is 17*9 all 4 rims, might really have to think about selling em.
But i really like these drifteks man, anyone got any to swap =)
Edited by cjlancer
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
