Would anyone be able to tell me if these measurments would fit my car? Im planning on buying rims tommorow but because my car is at the machanics i have no car to test on.
Size is:
17"x9 with +18offset
Im just wondering if theres any modifications needed to fit these?
Would it clear calipers?
Would it rub gaurds?
Im also running on cusco adjustable suspensions if that helps!
Thanks guys!
https://www.sau.com.au/forums/topic/155713-17x9-on-a-r33-s2-with-18-offset/
  • 4 weeks later...
Hrrmmmm your right it does stick out of gaurds roughly 3 cms. With my coilovers lowered it will hit the gaurds. And the insurance company said that itll be illegal to have the whell sticking out of gaurds.
Anyone have any ideas what i should do?
I was planning on having my gaurds rolled out and raise the suspension.
Would that make it more legal, or should i sell out the rims?
Edited by cjlancer
You will deff need to roll the guards dude.
Those offsets are for gtrs which have a more pumped guards than gtsts..
Sell the rims,
And get offsets at min or 30 for a gtsts..
30 front, you might just have to roll it a little..
Anything below 30 offset, will just hit the guards easily.. plus it will look gay anyways.. lol
I reckon for 17inch rims, 32 offset front, 35-37 offset rear is best combination..
Plus you already have 9inch wide rim.. It will look phat!!
Btw is that 17*9 all the way around?
Im not to sure if the fronts will fit then.. AS in, it might touch your coilovers..
In short, those rims are for GTR's!!
Edited by siddr20
Ive got some stretched tyres at the front already with 235s, rears are 265. But it causes alot of camber wear.
It is 17*9 all 4 rims, might really have to think about selling em.
But i really like these drifteks man, anyone got any to swap =)
Edited by cjlancer
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
