hey everybody
i have a standard airbox+intake+k&n hi flow filter+ recharge kit for k&n
the panel filter still has spool up noise...and the recharge kit allows you to clean when ever you want
fine condition
$130 for the lot, i think is fair casue the filter is pricey and so was the recharge kit
im in sydney, sutherland shire......
also i have a standard ecu for r33gtst, some1 can have that for $50..dont have any pics on me but you know what they look like!!
pm me, msg call me i dont mind
mitch-0405204561
https://www.sau.com.au/forums/topic/155722-r33-intake-for-sale-r33-ecu/
just so you know, it doesn't really matter if the ecu is series 1 or 2. they are the same thing. some people think that the series 2 has an ignitor built in, but they don't. otherwise apexi would've made a different power fc's for the different series, but there is just the one.
are you saying the ecu has an ignitor built in? i think you might be referring to coil packs.
Series 1 coil packs have an ignitor built in, where as series 2 does not.
other way round. the series 2 coils have the ignitor built in. series 1 have it at the back of the rocker cover.
some people think that the series 2 ignitor is in the ecu, but they are wrong.
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
