is it possible to buy some sort of adaptor to fit this turbo? is it rated higher that the standard RB25 turbo? can the front housing of the bb unit be hybrid-fitted to the read housing of the RB turbo? just need to have this cleared out before i blow my money on sometihng that wont work...
CHEERS
https://www.sau.com.au/forums/topic/155765-can-fit-gt28bb-to-rb25/
This may help:
http://www.skylinesaustralia.com/forums/in...&hl=GT2871*
The same principle applies for any of the GT28 series. If you were to choose a GT28RS Discopotato to base it on, you would pretty much just pick up the whole turbo and graft the Nissan/Hitachi turbine housing onto it. Close to same spec as a HKS 2530.
For the larger 71 and 76mm compressors you have the option of either using the OE comp cover, or the Garrett cover.
FWIW, I still find it hard to stop smiling each time I drive mine with the 2871 based high flow. Provides a good lesson in response and driveability because it has torque anytime you need it. Pulls high gears so easily it's just like it has another 1.5 litres capacity rather than a smallish high flow.
PM me if you want any further detail, but the thread is fairly self explanatory.
Edited by Dale FZ1
