Ok guys, i have a mate that has spent nearly $40,000 on his RB25. It has a bit of shit done to it this is the list
Areas pistons
Cunningham rods
Metal head gasket
Head work
Deaek bottom end and bored
Blue print and balanced
N1 oil pump
N1 bearing kit
GT 35-40 garret turbo
Massive FMIC
Custom plenum and throttle body
MSD DIS4 ignition system
Ltx 12 microtech.
Now it was dynoed at 360 rwhp at 19 psi, i thought with all that work it would make at least 450rwhp plus.
I notice alot of other Skylines with not much work done coming very close to 360 rwhp.
Is it time for a new tuner or is that it.
What do you think.
https://www.sau.com.au/forums/topic/155778-should-it-make-more-power/
  • Replies 46
Posted Images
sounds like your mate has been ripped off. Not by the amount of power he is making, but for the small list of parts you have shown. I hope that $40k covers a hole bunch of other things. :P
Well yeah thats what i think, thats a shit load of money.
But alot of work has gone into it.
There is not much more.
Or forgot these.
ARP stud kit.
Coil pack
1100kg exedy twin plate
1.15 A/R exhaust housing.
Mate it adds up pretty quick.
Labour was a few thousand.
Edited by subzeroR33
Head, Cams, valve springs, fuel, compression, leakdown, exhaust, cam timing, catalytic converter, tune and................ the dyno. What are others doing on the same dyno?
Try another tuner see what they think may be up with it....
It still has standard cams.
But i think it should be better than 360rwhp.
Then they usually do cams, the plenum possibly exhaust manifold already done.
Modifications done in stages. When everything has basically been done at once its just too difficult to know whats wrong with the car.
It may simple come down to the tuner, a stuffed cat, a crappy exhaust. Who knows, we don't because maybe you don't either.
If you were the owner you could say ... yes its running a decat, 3.5" straight through muffler this that etc..
lol $40,000k? for only 360rwhp?
HAHAHAHAH your mate has been owned big time..... does he not know how to do anything himself?
If he had 40,000k to spend on an engine he should of bought a twin turbo jza80 supra and spent the money to have an 800hp monster but each to his own i guess....
I have spent like 2k on my car for engine mods and am making in the vicinity of 260rwhp.
I know that to go up i must get a new turbo, computer etc but i would still want to come out f*cking short of 40,000.....
I hope that 40,000 inlcudes bodykits, wheels etc etc....
The parts listed are a fair cry from 40k. Doesnt even come close to knocking over 20k
I'd say the figure of 40k was including things like rims, suspension, body kits etc etc etc etc.
But as cubes said (i did not have the time earlier), they are a LOT of things missing.
Even the turbo spec iteself.
All thats been listed is about 1/2, and its not enough detail for the items that are there, let alone whats missing
Maybe the FMIC has pressure drop, maybe the head gasket a whopper and its dropped the comp ratio substancially meaning mroe boost would be required.
Subzero, get your mate to signup and give the FULL detail and history, no-one can really help unless there is basically a thesis on what parts are there, whats been done, whats been tried.
What has not been tried etc etc. Its a lot more detailed that just listing some of the parts that have been used.
Simply saying a car isnt performing and asking for answers is like asking how long is a piece of string.
Ps. im moving this to Forced Induction.
its a 3540. bleh.
cams and headwork. also a plenum that doesnt work.
ive a stock 26 with a t04z. only makes 410hp atw. on 20 pound lol.
cams and headwork. and posibly the ebay exhaust manifold.
where as my old 26 with mild cams and portwork made 440hp atw with a t04e on 1 bar. with a exhaust manifold i made.
    • Before I commit to it as I already have the wastegate off the car, would you change it to the 9psi spring instead of the 12, or whack it back on now and try your suggestion?
    • Sounds good Hmm suppose the main thing is, how much do you care about this car? The filler doesn't make for a very good water barrier lol. If there was a tiny little bit of rust forming now, that in 3 to 5 years time becomes obvious under the paint (starts to bubble up), would it bother you?
    • I already have the ability to datalog the voltage... what I can't do is correlate it to what the gauge is showing when I'm looking at the data at a later date. Or something like this. Except getting the oil to 125C+ involves me going 200+kmh at the track so you can imagine this is a little tricky unless I do something like note what the voltage is when I am at the top of 5th gear so I have a point to reference on. Drove car today. O2 still reading richer because hopefully not a leak instead of massive restriction I've introduced. Car really doesn't sound like a LS. It's quite strange. Pulled a bit of fuel out up top. This does potentially explain why my spark plugs looked like the car was running pretty over-rich. If I was tuning it to a ~12.7 which in reality was far richer than that in the past. It will be handy to have the dyno WB to compare my WB to to compare notes that's for sure. At this point I'm happy to just sit in the passenger seat and tune the thing given I've got about 7 million hours on the platform lol.
    • Yeah I understand you have to pay for an updated map or subscription service or something. But I can't even find a current map for Australia. My map is dated 2017, but didn't this car version still sell in Australia until 2021?   Also, just as an aside, the navigation system warns you of traffic incidences ahead.....why would they include that on a map they knew is not receiving live information. I am forever going to be warned of an incident that probably existed for 30 minutes 8 years ago.
    • Car has been sold and I am now selling leftover parts. Prices are non-negotiable as I will sell to my mechanic if it won't sell here. Prices are firm except for the Random Parts listed at the very bottom. All parts are genuine except for the S-Tune front bumper. Volk Racing TE37SL 19×10.5″ +12 5×114.3 pressed graphite with P-Zero 275 30 19 tyres [USED] $4,500 Wheels are in perfect condition, have been sitting in my garage for the past 6 years. Tyres still have 90% tread, but since they're now old, I would not recommend you drive hard on them. K-Sport Super Sport External Reservoir Coilovers (made to order) [NEW] $2,500 Front spring rate 14kg, Rear spring rate 7.5kg Fork Type. You can read all about it here (https://www.k-sportracing.com/product_detail.php?Key=12). I was going to start tracking the GTR, but never got around to it. Paid $3500 (after USD conversion and taxes). HKS Kansai Service Tower Bar [NEW] $500 Never fitted in the original Japanese box. R34 GTR S-Tune Fibreglass Bumper [NEW] $500 No mesh - No Box - No damage - just dusty. Nitto RB26 Clear Timing Cover [NEW] $50 Couldn't fit RB2630 due to bonnet clearance. HKS Piping Kit Special Type (BNR34) & Apexi Power Intake Air Filter Kit & Password JDM Adapter [USED] $1,000 Missing some rubber hoses and supports, but you get what you see. Nismo NE-1 Weldina Turbo Back Exhaust & Custom 3.5"straight pipe [USED] $1,000 Needs some love, but perfect for those who want to go back to OEM+. Bayside Blue Aluminium Vspec Bonnet/Hood [USED] $700 Came off my GTR. Unfortunately, the tips have been slightly ground down. It will need some repairing. Bride Low Max Super Seat Rails [USED] $350 The price is for both sides. Will post pictures when I get a chance. Random Parts [USED] - negotiable Standard rb26 cams (intake and exhaust) $10 Stock amber front indicators $10 Standard GTR bumper lower side grills $10 Stock amber side indicators $10 Nismo Sports Resetting ECU $50 Water reservoir $10 Stock airbox mouth $10 Stock fuel rail $10 Stock coilovers from R34 GTR Vspec $100 PM me which items you are interested in. I do work 9-5, so I will be responding daily at best. Best time for pick up is after 5 and before 7 on weekdays, or i can work something out on weekends. I will only accept cash or PayID. Pick up only - located Epping NSW area.
