Yeah I am fairly certain that the SET GAIN is too high which is causing your issue.
Your setup seems correct, I also have a blocked off pipe which appears to be in the same location.
It was blocked when i got my car, so the previous owner in Japan must have had an EBC in it, but removed it.
I am at work atm, so i will have a look in a bit and let you know...
From memory these are the following settings for my Profec B Spec 2 on my RB20.
SET = 55%
GAIN = 5%
SET GAIN = 0.53bar (7.687014 psi)
WARN = 0.95bar (13.77861 psi)
LIMITER =15%
I find reving out in high gears it sometimes reaches 1.00 bar (14.5038 psi)
I also find, that it does not reach optimal boost until i am reving at about 4500 to 5000 rpmish. I would like it to reach max boost sooner and hold all the way out through the rev range without creeping to much at high rpm. But the gain is turned down all the way....
Since it has gotten colder i have dropped it down to about 50%ish as it has been hitting 1 bar a bit more frequently :D
Haha cant complain about that :banana: Ill try your settings and see how i go with it, there shouldn't be too much difference between the settings between the Rb20 and the Rb25? Cheers man
There shouldn't be any difference when it comes to boost levels.
The power will be different of course due to a larger turbo on the RB25, but basic settings should be the same.
If you have a series 1 R33 with a steel compressor wheel it may be a little laggy so increasing the SET GAIN should allow the boost to come on quicker, but once again i am no expert and i have a R32 so i am only going by what i have read :banana:
Yes there will be a heap of difference between RB20 and RB25 settings unless you're running an RB20 actuator.
I also wouldn't put your SET GAIN to 5psi, A) it defeats the purpose of this function and B) that is when your stock actuator will be opening and it might create some issues.
Start conservatively with your SET GAIN at say 7psi then slowly bump it up until it starts to spike then back it off slightly.
A good way to tune SET GAIN:
1. pick desired boost level (12psi or 120)
2. tune gain to suit
3. SET GAIN to 3psi (30) less then max boost (Therefore 9psi or 90)
4. go for run, and watch the guage, does it spike or not?
a. Spikes: reduce SET GAIN in small increments
b. No Spike: increase SET GAIN in small increments till spike occurs, then go back 1 setting
I might have to give that a go today. Im currently only on 5.5psi for my Set Gain. Might bump it upto 9psi and see how i go. Set is quite high at 55% and Gain is at 15%. This sound right for around 12psi? Anyone feel free to add what settings they have for around that amount of boost. Cheers
What your settings are really depends on the turbo and the support gear, if you have a big, high flow exhaust you wont need as much set to get to the boost that you want, etc...
With my high-flow s2 turbo, to get to 11 pound I have about 28% set...
I would turn down your SET to something a little lower and and go for a few laps and then gradually turn it up until you reach the boost you require.
Turn your GAIN all the way down to 5% for the time being....
Mine SET is at 50% to 55% depending on the weather, but yours may be different to reach your desired boost....
Edited by Douse
  • 4 years later...
rather than start a new topic.....will do a stone-age bump. Having a small issue with mine, which is keeping the boost at 12psi in the mid-range revs. Seems to be that if I increase either set or gain, it will cause boost to go well over 12psi once you hit the higher revs, but boost is only 10-11 psi in the 3500-5000rpm range. This is for a hiflow stock turbo on r32 actuator.
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
