Well lucky me.. my drivers side power window cable snapped.
Anyone got any pointers on whom to go too to get a new cable made up instead of replacing the entire regulator assembly - or a good import wrecker in Melbourne dealing with R32 GTRs?
Nissan can get me the entire regulator assembly for $285 odd, plus a 2 week MINIMUM wait order from Japan. Kind of hard to take this option when everything else is still good, plus I would'nt mind being able to drive my car places soon...
Edited by paulR32gtr
https://www.sau.com.au/forums/topic/155799-r32gtr-power-window-cable-snapped/
I had the same thing i couldnt find anyone to replace the broken cable so i just went to just jap and did a exchange for a $100 (secondhand) whole assembly so you just bolt it straight back in. The cable actually starts off inside the plastic wheel and i found no possible way of removing the cable with out breaking the pulley in two. Hope this helps :mellow:
Thanks for that - turns out the R32 GTS-t coupe is the exact same part which figures - from Nissanspares in Brooklyn - much easier to come by.. $80 fix!!
Some other guy up in thomastown wanted $220 beacuse it came out of a GTR.... they love those three letters.
Not enough grease in the one I pulled out and filled with grime and sand etc - gave the replacement a good clean and some fresh grease and it's all working heaps better now - much smoother.
Yeh i forgot to mention that the gtst is the same. Good as gold. :)
  • 9 months later...
bit of a pain - fully disassemble the door essentially.
From memory:
1. Remove door trim
2. Remove top weather seal - it slides off but there are some clips in there that need to be pressed in - will piss you off no doubt but exercise patience... it will slide off easily in the end
3. Unbolt glass and remove
4. Undo motor electrical plug
5. I think I might have even unbolted the motor as well - can't remember - if you can get at it might make it easier
6. Unbolt the assembly and slide out
I would also mark or measure the adjustment settings for the four bolts/nuts that hold the reg. assembly in so you can get it back how it was - otherwise takes a little while adjusting to get it perfect.
Good luck!
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
