paulR32gtr Posted February 10, 2007 Share Posted February 10, 2007 (edited) Well lucky me.. my drivers side power window cable snapped. Anyone got any pointers on whom to go too to get a new cable made up instead of replacing the entire regulator assembly - or a good import wrecker in Melbourne dealing with R32 GTRs? Nissan can get me the entire regulator assembly for $285 odd, plus a 2 week MINIMUM wait order from Japan. Kind of hard to take this option when everything else is still good, plus I would'nt mind being able to drive my car places soon... Edited February 10, 2007 by paulR32gtr Link to comment https://www.sau.com.au/forums/topic/155799-r32gtr-power-window-cable-snapped/ Share on other sites More sharing options...
95SKY Posted February 11, 2007 Share Posted February 11, 2007 I had the same thing i couldnt find anyone to replace the broken cable so i just went to just jap and did a exchange for a $100 (secondhand) whole assembly so you just bolt it straight back in. The cable actually starts off inside the plastic wheel and i found no possible way of removing the cable with out breaking the pulley in two. Hope this helps Link to comment https://www.sau.com.au/forums/topic/155799-r32gtr-power-window-cable-snapped/#findComment-2897839 Share on other sites More sharing options...
paulR32gtr Posted February 12, 2007 Author Share Posted February 12, 2007 Thanks for that - turns out the R32 GTS-t coupe is the exact same part which figures - from Nissanspares in Brooklyn - much easier to come by.. $80 fix!! Some other guy up in thomastown wanted $220 beacuse it came out of a GTR.... they love those three letters. Not enough grease in the one I pulled out and filled with grime and sand etc - gave the replacement a good clean and some fresh grease and it's all working heaps better now - much smoother. Link to comment https://www.sau.com.au/forums/topic/155799-r32gtr-power-window-cable-snapped/#findComment-2900223 Share on other sites More sharing options...
95SKY Posted February 13, 2007 Share Posted February 13, 2007 Thanks for that - turns out the R32 GTS-t coupe is the exact same part which figures - from Nissanspares in Brooklyn - much easier to come by.. $80 fix!! Some other guy up in thomastown wanted $220 beacuse it came out of a GTR.... they love those three letters. Not enough grease in the one I pulled out and filled with grime and sand etc - gave the replacement a good clean and some fresh grease and it's all working heaps better now - much smoother. Yeh i forgot to mention that the gtst is the same. Good as gold. Link to comment https://www.sau.com.au/forums/topic/155799-r32gtr-power-window-cable-snapped/#findComment-2901838 Share on other sites More sharing options...
julion Posted November 14, 2007 Share Posted November 14, 2007 How did you guys go about getting the power window assembly out in order to replace it? Link to comment https://www.sau.com.au/forums/topic/155799-r32gtr-power-window-cable-snapped/#findComment-3474480 Share on other sites More sharing options...
paulR32gtr Posted November 14, 2007 Author Share Posted November 14, 2007 (edited) bit of a pain - fully disassemble the door essentially. From memory: 1. Remove door trim 2. Remove top weather seal - it slides off but there are some clips in there that need to be pressed in - will piss you off no doubt but exercise patience... it will slide off easily in the end 3. Unbolt glass and remove 4. Undo motor electrical plug 5. I think I might have even unbolted the motor as well - can't remember - if you can get at it might make it easier 6. Unbolt the assembly and slide out I would also mark or measure the adjustment settings for the four bolts/nuts that hold the reg. assembly in so you can get it back how it was - otherwise takes a little while adjusting to get it perfect. Good luck! Edited November 14, 2007 by paulR32gtr Link to comment https://www.sau.com.au/forums/topic/155799-r32gtr-power-window-cable-snapped/#findComment-3475024 Share on other sites More sharing options...
