hey all,
i followed the diagram on the closed thread about modding the stock R33 bov to make it flutter.
and it sounds nuts but i am having problems with my car stalling.
it only happens if i bring the revs up and drop them fast. it ALWAYS stalls without fail.
e.g. im in first/second gear and i take the revs to 3-4 then push the clutch in. the revs drop to below 1 and it STALLs.
its fine if i rev them to 3-4 push clutch in, change gear and let out the clutch.
i thought perphaps adjusting my idle would stop it?
please help me because i cant leave this flutter on if my car is gonna keep stalling.
cheers all
  • Replies 50
its stalling cos you are dumping measured air to the atmosphere
the ecu doesnt know so its extra rich, cos its missing air
put the bov how nissan intended it
or get a bov stall hack device
You want a bit of wank factor, you get stall.
Thats just how life is.
Otherwise fork out for an aftermarket ECU and have it tuned out.
paul you really are a dick. learn to read.
Rochey: did you squash the top of the bov, or plug up the recirulation hose? either way you have stopped air from going the way it is supposed to so it is going back out the intake and being read twice, so the car is running rich.
you have 2 options. 1 will defiantely work, the other may not.
1) return the setup back to standard.
2) put a new set of spark plugs in. i know people with aftermarket atmo bovs that have no issues with stalling. they put the bov on, it made it stall a bit, they put new plugs in and it went away. i even had the stalling issue on my stock bov when my plugs were shagged.
Plugs stop stalling from a blanked off BOV?
:D
He followed the guide on how to make the stock BOV hold more pressure.
He isn't dumping air into the atmosphere at all.
Quite the opposite, he's letting NONE out!
Have a read. :D
http://autospeed.drive.com.au/cms/A_1457/article.html
all i did was put a piece of tin between the stock bov and the manifold its connected too. i left the lil hose on the bov connected as i didnt see the point of disconnecting it and plugging it up if leaving it connectied to the bov would do the same thing.
so changing my spark plugs would do it ya recon?
So an aftermarket ecu would prevent it from stalling even tho he would still have the afm there?
Or would it completely stop it from stalling if he had an ecu without a map sensor? but then he'd be screwed with cold start... you cant win just leave it plumb back
EDIT : Or buy a safc2 and get that tuned...
i (and a few mates) had the stalling issue that everyone attributes to atmo bovs, except for the fact i have a 100% stock bov.
the reason that a new set of plugs may fix it is that if the old plugs are getting old they will be foulded and the gap may be bigger than needed. so by putting in a new set of plugs you get a stronger spark which will burn up the extra fuel.
new plugs have solved the stalling issue on a few different turbo cars i know, all but 2 with atmo bovs.
Thats just a band aid fix (if it does work which i've never heard of)... to fix it properly you need a form of engine management like R31Nismoid said... safc2 is designed to help with this EXACT issue.. and your car will run better aswell...
EDIT : Please show proof of this band aid fix and how logically a spark plug can compensate for the amount of extra fuel thrown in to make it stall... i understand it for missfire but not for full on stalling.
Sorry, a bit OT, but how does a map sensor stuff cold start(id really hate to own a $40,000 supra with cold start issues)
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
    • No, I don't remember the exact reasoning (was 20 years ago!) but the cops didn't end up supplying it to us either. Actually my mother went through a similar thing recently where she was hit when stationary, flustered and didn't get address (she got plate details, name, phone and insurance company, but not address). Person who hit her blocked her number and their insurance company (naturally) would not provide any details. Her insurance company also required her to pay the at fault premium because she did not have the address, cops did not help as it is a minor civil matter (they said their only course was if the other driver had left the scene of the accident without providing any details). She only ended up getting that refunded because they happened to be insured with Suncorp and she was with APIA so same company owners. For some reason the address is critical in insurance companies recovering money from the at fault party
    • If you're driving something like an R32 through to R34, no chance of meeting Euro4. Euro4 came out in 2006, and car manufacturers back then were complaining how hard it would be to meet those regulations. Not a chance a vehicle 10 years earlier is going to be compliant.
