I agree with this, my car also suffers the same prob due to having the flutter, you'll get used to it and you will learn how not to make it stall, theres no need to snap your foot off the accelerator pedal anyhow unless you must break suddenly which happens everynow and again.
if it stalls clutch start it, you will be rolling anyhow, if your good enough just play with the accelerator while the clutch is in until the revs stabilize, you'll get the hang of it
yeh thats cool, it aint a major safety issue. the fact is my car is running rich, which i dont like the sounds of. i want my car to run normal. i understand 'i want the wank factor, i have to accept the stalls.'
ill try new spark plugs. c how it goes.
  • Replies 50
would you be talking about red-top sr20s? they actually do have a bov. its right next to the stock intercooler. i use the one off my old 180sx as a paper weight.
No was refering to the redtop rb20dets, found in HR31 skylines.
there are lots of cars out there that run fine with the stock ecu and atmo/no bov. skylines just seem to be the most tempremental with everything to do with turbo motors. look at the sr20. you can screw heaps of boost through it and the ecu won't cut out, the turbo won't spit the exhaust wheel out the back, you can run atmo bovs or no bov without any dramas.
Yea i've noticed that alot... blocked or atmo bov on sr20's dun make em stall just make em pop and fart cos they're running that little bit richer...
My comments about the spark plug's not fixing the main issue is reffering to my personal experience with my own car.. i got a larger turbo fitted (Gt2876r)... blocked bov (cos they couldn't be farked making a return pipe for it)... no tune cos i hit 2 many brick walls and ran out of money very quickly... and its running 6psi and would not stop stalling... i drove back in and they said cos it's not recurculating the air back through the intake pipe (which i never knew about until it happend to me) thats why its stalling and idle hunting.. pissed me off bad especially after all the shit i went though with the 33...
So i got my friend to make my standard bov recurculate back to the intake pipe and it don't stall anymore.. and it dont boost over 6psi cos of the air it leaks (factory design).,. but yea for full blown stalling thats what i meant by "spark plugs wont help" but not for long anyways...
But i need my car tuned real bad... thats my own issue but i thaught i'd share lol ;)
The SR20DET not stalling due to blocked bov on its stock ecu..
You think that could be partially related to the smaller dia afm? Its quite possible the smaller afm prevents 'reversion' if you like. Similiar to that of the design of 'some' welll sorted exhaust manifolds.
It would be interesting to see what happens if one were to fit up an rb20/25 80mm afm and use a safc to modify the signal accordingly WITHOUT any tuning. (i.e HW4 in HW2 out or something along those lines)
Those who have fiddled with an SAFC or read the manual even will know what I mean.
I can confirm that my SR20 definitely stalled when car was near stock. I have a old schoold GFB Hybrid BOV, the type that both plums back and goes to atmo.
I can barely remember a time when it didn't stall or nearly stall when giving it heaps and then backing off suddenly. I have even asked a mechanic to look at the issue, and they couldn't find anything wrong.
Yea I use to have a safc 2.. i think there was the thing to change it between the afm's from different cars exactly like your saying between the sr20's afm and rb's afm... it should actually let the car start up and idle smoothly... but the safc 2's have that feature to stop cars from stalling with the use of decl air thingo
i used to own a 180sx with a GFB basic bov on it. it never stalled. another of my mates has a sr20 in a GH sigma with stock AFM and ecu and a bov he made himself, no stalling. his missus has a 180sx with an sr in it. when they got the car it didn't have a bov and didn't stall. now they have a greddy full atmo bov on it and it doesn't stall. another mate has a silvia with an atmo bov, again no stalling. another mate has a 180sx with a ca18 in it. no stalling issue.
yours must be 1 of the very few to do it. i'd check the condition of the spark plugs, and also see what gap and temp they are.
hey i saw a nissan tuner today that specialises in R32,33. 180, 200sx.
he recons drill a small hole in the tin i am using to block it off. that way some air gets out but the majority stays in it.
would this work? or would the smallest hole let out all the air due to the stock psi i am running?
  • 2 years later...
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
