Hey guys,
If you could only get 1 of the two mods mentioned above at one time - would would you get first?
Car is used for track days once a month as an idea.
basically reducing understeer and get some more negative camber - which would you get first up - as in if you could only get 1 due to funds etc.
ideas and comments please
:mellow:
Cheers guys!
static camber?
dynamic camber?
Im a n00b at suspension still....so yes, still learning the lingo!
how do both differ from each other?
the effect of caster is that it adds "dynamic camber" - the more you turn the wheel the more camber you get. but when you straighten the wheel, camber gets less. this is good because the tyres lean into the corner when they need to (under load) and not when you're driving straight.
For a street driven car, castor is definitely much better. Too much camber will wear your tyres too much. If you had an R32 though, I would go camber kit first because you gain castor as you increase camber due to the angle of the upper arm.
Get castor adjustment and get as much as you can without scrubbing your front bar.
Static camber: The amount of camber when there is no movement. No moving of the wheel up and down from bumps, no turning of the steering wheel.
Dynamic camber: The change in camber as the suspension goes through its travel and the effects of castor as you turn the wheel
Edited by salad
Hmm, having done the two mods in turn I would strongly recommend you do the camber adjustment BEFORE the caster adjustment. The amount of -ve camber the caster adds is suprisingly small when you have a quarter of turn of lock on. Certainly much less than the one degree or so a camber kit will offer. Skylines need -ve camber at the front to generate cornering grip, otherwise you just end up with an understeering pig.
Also, if you haven't already you need to get the cars roll under control - which means sway bars & dampers.
Any even half serious track day will consume tyres at a far greater rate than even a large amount of road travel. Once a month is a lot of track time as far as tyres are concerned. You wil probably chunk the tread blocks - hence I would suggest getting yourself a proper track tyre even if it is only a Falken or Federal or similar.
thanks for the reply guys, I think at this stage I'll go the front adjustable caster and f & r sway bars.
:laugh:
I've been reading this thread with great interest, as my car understeers a bit too.
Any idea on a good adjustable camber kit? I'm not sure where to start.
cheers,
padey
cheers,
padey
You won't stop an R32 R understeering until you either dial in some more -ve camber and/or get the front end roll under control. Check the group buy section for Whiteline bits. I would recommend using something like this kit rather than the Noltec style upper arms or the other Midori style upper links. don;t worry about caster either as this does very little to help things.
Also do a search for the part number to see a useful discussion on the same.
is that just in regards to the 32 gtr's?
No. In fact it is a truism for almost all cars heading out onto a circuit.
To be properly balanced you don't want much steering lock through the corner. Any more than about a quarter on a GT-R & it is an ugly thing. With this relatively small amount of lock you really need ALOT of caster to make a difference. R32 GT-R's only have 3 degrees. Going to 4 or 5 makes the steering heavier & more self centring (Which is why drift nuggets love caster) but really doesn't do much for your grip.
It is one of those things that if fine as far as it goes, but is secondary to other, more important parameters, ie camber.
Edited by djr81
well, personally I loved the difference the caster made. but yes the camber is important too, and overall makes a much bigger difference to mid corner grip. but I did like the feel at turn in with more caster (and yes I did both seperately).
before doing camber and caster I'd say look at sway bars, shocks and springs, and then you may as well do camber and caster too as they can be done cheaply if you use the offset bushes.
personally I have the midori arms and don't have any problem with them, but I'm about to try out the noltec ones so I'll let you know what they are like.
But as was said....extra camber is a disaster for street tyre wear, they can often have too much already once you lower them a bit.
Do the sway bars and caster kit first I reckon
The thing that caught my eye was that he was talking about track days once a month. That sort of regime will punish the tyres much harder on the track than on the road. Hence the suggestion of doing the camber first.
Edit: gees, I wish I could spell.
Edited by djr81
you should get firefox. It spell checks for you :huh:
Seeing as we are now talking about sway bars, I'd have to agree that of everything i've done it has made the biggest diffence to the cornering of my car (with the possible exception of running semi slicks)
you should get firefox. It spell checks for you :P
Work computer. But I probably should have paid attention at school too. :huh:
For me the biggest difference was new dampers. Just a different world. Sway bars weren't that huge for me.
Dampers do a lot, but they're probably not the most cost effective method of improving handling as good dampers aren't cheap. Swaybars however, are quite cheap and I also found that they did quite a bit in improving handling.
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
