No Compliance Plate On Car....
Antone
 Share
Hey guys,
just a quick one...
i just checked out a 91 r32 mspec, and noticed it doesnt have the green complaince plate like other skylines.
Allthouh it does have a pink sticker with "used import plate" on it.
should it have the green plate tho??
Isnt a pink plate for a used private import? As in the owner had it in japan for over 12 months and then imported it to Australia.
And the green one is for regular SEVS or RAWS or whatever.
OK, after thinking about it, since it is a 91 model it must be a used private import, as only July 1992 onwards cars can be imported under SEVS/RAWS. (As Nissan sold the R32 GTR in Aus before then.)
That and the 1989 models that came in under the 15 year old scheme.
Rhett
rhett, it's a 32 mspec,so clear sailing for a 1991 import.
the pink stickers are the new compliance "plates", not just for "personal" imports.
isn't a "private" import just one you've done yourself? ie you've organised compliance, customs, shipping... etc, etc, without using ie. J-Spec, as opposed to a car you've owned outside of oz for over 12 months, that being a "personal" import?
my R34 came under SEVS, and as such... i ONLY get a sticker
it's fine imo, my car doesn't have a green plate, because it came in under SEVS. Post this thread or a link to this thread in the 'importing' section. You'll get some answers from the people in the biz from there
I'm 98% sure that under the old SEVS rules that ANY R32 older than July 1992 could not be imported, be it a GTR or GTSt or GTSt Type-M.
Under the old scheme, there were two types of compliance plates - blue ones for SEVS imports (the majority of them) and pink/orange ones for private imports - cars which the owner had in japan for at least a year, then moved to Aus and bought it over with them.
So there should never be a 90-June 92 R32 in Australia with a blue compliance plate. The 1990 to June 1992 cars must be private imports with pink/orange comp plates.
I emailed RAWS about my own one and apparently they are putting stickers rather than plates on now. I just hate how they put it on a strange angle on the strut tower rather than on the firewall. Apparently your not allowed to move it either!
My 89 gtst 4 door has nothing and my mates 90 gtst has a green one.
i'm confused ( won't take much )
The green plates are on cars that were complied a few years ago under the old sevs scheme
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
