No Compliance Plate On Car....
Antone
 Share
The original Nissan build plate is blue (most cars have these on them still, some have them removed).
The green plate is the old compliancing scheme (pre 2005 I think?)
The purpley-pink sticker or plate is the new SEVS compliancing scheme.
  • 4 years later...
Recently bought a 2nd hand R32 GTR registerred in Victoria. Checked out RTA website and it all looks correct.
There is NO compliance plate.
VIN is engraved on strut tower (drivers side)
Will i have issues with the ID check? What do they expect you to do if the VIN is engraved?
Some more feedback from other peoples experiences would be good
Cheers
Cheers
1989 Model?
Mine, my old 32GTR & a mates 89 R32 GTRs have no purple / green compliance plates.
All came in under 15 year rule (loop hole closed). I passed pits no worries cause the jap vin is on the system and it had been registered before.
Just grab the Jap vin, call REVS.
Edited by 10 4
My car is listed as a 92 model (VicRoads)
I did do a little more reading of the forum last night and found a purple/pink sticker on the passenger door jam, so things are starting to look OK
Need to get the car on a hoist and assess how much aftermarket gear i will have to revert to stock. The car looks fairly stock to me, exept for exhaust, BOV (very annoying), turbo timer, etc.
Do ppl have any issues with oil catch systems?
Anyway, Back on topic. My car appears to have a Pink/Purple sticker, however..
I read somewhere ppl having issue with an engraved VIN, rather than stamped? Can anyone shed some light?
purple sticker means its complied and ready for rego. take it to your local registrar and pay them. job done. it was the steel plated VIN tags that vicroads went nuts on. if it was stamped into the body then there usually was not a probelm.
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
