You's have it lucky, when I'm driving my dads van with my P's up I get stopped more than driving my usual car, mind you its a cleaning van. Once drink test and another drug test and a quick peak in the van.
I hate tossers who look at your freshly cleaned sparkling paint job that you have painstakingly kept up an waxed etc. then decide hey .. I know what would be fun, lets grab a key an run it right down the centre of the drivers door.... awsome.
Its not like i had parked it klike a dick or anything it was centred in its own spot... like wtf? f'n shits me royally
wow... you got randomly pulled over for a random breath test.
That's such terrible victimisation.
wat did u only read the first paragraph of his story or sumthin???
obviosuly the cop was being a dik...so wats with the sarcasm??
LoL tightass cops... i understand they're doing a job but with their power trips some of em think their judge dredd or sumfin...
Get used to it.
You own an import,
They have the power.
um...welcome to the import world. if ur gonna start a thread everytime u get f**ked around by a cop ur post count is gonna rise pretty quickly.
zackly. and yes the Police act badly sometimes...just like import owners
yeah that exactly why .. so i can get my posts up. :D just though i would share an experience that i had. been driving for 4 years and never had a problem.. sorry to some for expressing it.
Get used to it.
You own an import,
And yaf28f: Legal noise limit is not 95DBa, it's actually 90DBa.
Whoops, that was a TYPO. I meant to say 90 as I got defecteded at 93.6db at 3,200 RPM in the past.
But I don't really like that qoute.
'Get used to it.
You own an import,
It's just like saying, get uses to it, your a muslim and they have a power in a christian society.
Just because a couple of people give your group a bad name, it doesn't mean you should get discriminated against.
It's probably not the best example. but I'm sure everyone gets the idea. Religion just like owning an import is a choice and you shouldn't be picked on because of stereo typing.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
