Just want to tell everyone that I went to boostworx for a tune (safc) recently and I would highly recommend Shaun's work to anyone!!
I gained 10kw just in tuning/ignition timing because my last tuner was a little too conservative (was still a good tune, but just maybe he doesn't specialise in nissan/apexi tuning as much as others).
Shaun's ability with skylines/stageas is top notch - as many people on this forum will agree.
I'm very happy with my car's extra performance! Worth every penny! (prices are very low too) :D
EDIT: P.S. when I say the other tuner was conservative, for example my AFR's were sitting below 11:1 and ignition timing was either stock or a bit retarded ...Shaun managed to get the AFR's up to a flat line at 12:1 and advanced the timing whilst still keeping it safe. :yes:
Edited by pixel8r
  • Replies 80
Posted Images
Getting my car back 2day and getting my tune there soon after my FMIC.
Good stuff Paul. Try to book early otherwise you may end up waiting for 3weeks to get it in.
My plans have changed.. lol I'm going a GT35r .82 int gate turbine with an xr6 .5 comp cover.
Should do exactly what I want it to. :)
Yes Shuan is a top bloke, Mate and i were there yesterday working on his IP race car, whilst Shaun was working on his! I'm starting to think he needs to employ another off sider! he is always booked to the max, and not too mention they are the "Dyno Day Kings"
Ive decided on Boostworx for my tune on the RB25det stagea. Original 2 tunes were with Graham West Workshops but I feel they are on the expensive side, and was going to go to Turbo Tune but thought bugga it, lets do Boostworx seeing they have such a wide support network here on the forum.
Next Tuesday 27th Feb at 9am for a few hours is the golden day. Dropping the front AWD driveshaft and tuning in RWD mode.
Question to the experts : had the highflow turbo from Slide on now since November, worried about afr's etc with the summer heat (been on low boost, in fact hardly driven it in the heat). Should I go for a 1bar or a 1.1bar tune? Dont want to stress the motor over the next handful of years, as I wouldnt be able to afford a rebuild. Maybe in 5yrs time but not in the near future.......... opinions ?
She's got all the bits bolted on her, such as 040 fuel pump, dual stage EBC, Z32 afm, apexi SAFCii and SITC pigybacks, fmic, cai with pod filter, radiator air guide, etc etc etc, loads of goodies.
A: dont be to soft on it, or she will carbon up to much.
1.5 Bar should clean out the cobwebs and get the stag really humming..
or
b: 16 psi will be fine, just make sure on boost your AFR is around 11.5 and no higher.
and keep pinging below 15 and it will last forever...
if your really concerned about it lasting for years in the heat, then get it tuned on 95 ron fuel,
once tuned only run 98 ron fuel and you will never have an issue when it gets hot.
how much power are you looking for?
Darren
Shaun will see how it goes on the day, i.e slowly wind boost up until the limits of the std ecu and piggy backs are reached.
Do the Stagea's still have the dreaded R&R? This will be its limitation BUT with an adjustable fuel pressure regulator you may be able to push up fuel pressure and then lean it right out with the safc, you won't have to worry about it pinging its head off due to the lesser load points and more ignition it runs as you can pull ignition out with the ITC.
Looks good. ;)
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
