Hey all
how much boost and how many kws of power can a rb25det take (obviously depending on driving style, but generally...)?
my rb is pushing 230-240 at the wheels on 20psi (very rarely on max boost) im just worried the internals are gonna kark it...
Should i be heaps concerned about making more then 250 on stock internals or can the pistons n stuff take more?
Cheers
Edited by DjeMz
https://www.sau.com.au/forums/topic/155907-how-much-power-is-tooooo-much/
  • Replies 56
As above
There are many topics on this.
Its each to their own. You can make over 300rwkw, but most people dont have it that way daily, and to my knowledge the others have have not, all died at some point
i have a mate who has a rb25 runnin 280rwkw... bigger turbo blah blah but yeah its not showing any signs of dying any time soon...
Theres a guy here in the states who had an rb25 with 595 rwhp in his Z car.
Keyword *had* the internals held up for a while.. But man, thats pushing it... Thats a ton of horsepower even WITH a good tune.
yeh mine made 254 and went bang after 3 months but that was due to bad tuning aswell but....i know theres a dude here in sa making over 300 on the stock internals and has done for a while
Over 300rwkw on stock internals?! That must be an amazingly good tune...
hahahha
well the 25 is in a s13 silvia... and std computer, std injectors.. standard everything except for GTR pump... lol
i didnt believe it untill i seen the dyno read out...
neways he is building another motor with gtr rods n pistions...
neways he knows what he wants :P
I had 350hp for ages before a hole ended up in piston 1, but that was down to either injector failure or a crank angle sensor problem I had. A mate has 410hp on his & thats still going, but it would probably go if he kept it on full boost for a while.
impressive gt-passage.
so in theory a bigger turbo with less boost is safer than a smaller turbo with more psi making the same power? sure it will be a bit laggier but will be safer for standard internaled rb25? is this a valid theory? common knowledge?
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
