  • Replies 56
It depends if it is a chipped r32 rb20 or 25 ecu, or a stock or chipped r33 ecu, i cant see it possibly being a stock r33 ecu. In my experience there is no such thing as a freak car, maybe 10 rwkw, but not 50, and ive done 100s of power runs in cars. If it makes that power, it does it for a reason. It appears to have the supporting hardware, now its just the injectors and management, you need to pull the cover off theecu and have a look.
yeah might pull the cover off this weekend and have a look to see if something funky has been done to it
oh, and you simply can't make 270rwkw on 10.7:1 afrs...
ok thats prolly a fair statement, any tuners on here care to have a look at the dyno graph i posted up and back that statement up?? its just that throwing a random comment out there like that dont carry much merrit unless you can back it up... now you could be right and you prolly are, but i have had it on the dyno, done the mph to back it up so if someone can come up with any sort of explanation why it could be otherwise, id really like to know?
I'm a tuner, and a car running 10.7:1 afrs just bog down too much. It might be possible to make that sort of power with a heaps big turbo, but I hardly see it happening with a GT30 or something that size.
There so many factors involved.
I also agree with Adriano - There is no such thing as a freak car. There is a reason why the car behaves like that.
i see
11.7afr @ 3200rpm ~ 90kmh
richens up to 11.2 and then leans back out again
11.8afr @ 4100rpm ~ 115kmh
progressively richens up to 10.8 afr around 4800rpm ~ 135kmh
then leans back out to 11.8afr around 5700rpm ~ 160kmh
then it progressively leans out to 12.1 afr before redline
i suspect you would get a good chunk of midrange power if the afrs were around 12 all the way through instead of richen up to high 10s and the back ground mid 11s. providing the egt's are ok it should be fine on low 12s the whole way through, usually a bit richer during boost build say upto 3400rpm ish~
your boost seems to ramp finally at 3900 so maybe a tiny bit before that a bit richer could help, then just 12s the rest of the way, again check afrs and egts on a dyno
hey Jono
have another look..
you say your a tuner yet you cant read a dyno printout ??
the 10.7 AFR is his first run in green = 207 kws
next run in red with AFR up to 12.1 = 270kws
he obviuosly started at 207kws then cranked some more boost into her and then did the red run
gettin up 270 od kws.
Have I got this right,
278 rwkw
RB25DET
delta fin cooler
3" exhaust
gt3037 @ 14psi
38mm external gate with screamer
sub zero plenum
injectors are stock as far as im aware
afm is stock
In a Silvia
Ts = 118 mph
I agree, it doesn’t add up.
1. The TS should be 125 mph or so for that sort of power and weight.
2. The AFM will be reaching 5 volts at a bit less than 4,500 rpm (~220 rwkw). That leaves 3,000 rpm of only mapping via RPM points
3. The standard ECU doesn’t like that sort of stuff at all
4. Someone put a SubZero plenum on and left the injectors standard, seems illogical to me
5. The standard injectors flow 370 cc’s at standard pressure (36-38 psi). That’s 370 bhp, or ~215 rwkw. So 278 rwkw out of standard injectors at standard pressure is impossible.
6. The A/F ratios being all over the place, particularly the richness ~4,200 rpm to 6,000 rpm, indicates larger than standard injectors are likely.
7. The reason why it is hard to drive down the ¼ is the non linear response from the engine due to the tune being all over the place
My guesses, Z32 AFM, chipped/bent ECU and 500 cc injectors.
Fix the tune and it will make a bit more max power (over 300 rwkw), a heap more average power (particularly in the all important 4 to 6,000rpm range) and it will be much faster and more consistent down the ¼.
:mad: cheers :D
Is that the 280rwkw car your talking about?
Std injectors & ECU?
not possible.
backed it up with a 118mph pass at the strip
the ecu has been remapped. the stock ecu has a speed cut at about 112mph (180kmh).
what does the car hit the rev limit at? if it is above 7000rpm then that is another sign the ecu has been remapped.
not possible.
ahhhh the point of the day, i dont have a speed limiter??? (she has been way past 180kph)
278 rwkw
RB25DET
delta fin cooler
3" exhaust
gt3037 @ 14psi
sub zero plenum
afm is stock
In a Silvia
Ts = 118 mph
I agree, it doesn’t add up. we both agree it dont add up
1. The TS should be 125 mph or so for that sort of power and weight. as stated i cant drive to save myself
2. The AFM will be reaching 5 volts at a bit less than 4,500 rpm (~220 rwkw). That leaves 3,000 rpm of only mapping via RPM points agreed
4. Someone put a SubZero plenum on and left the injectors standard, seems illogical to me i was offered the plenum for 200 bux and it retains the stock inlet runners and fuel rail thus the still standard injectors
5. The standard injectors flow 370 cc’s at standard pressure (36-38 psi). That’s 370 bhp, or ~215 rwkw. So 278 rwkw out of standard injectors at standard pressure is impossible. agreed
6. The A/F ratios being all over the place, particularly the richness ~4,200 rpm to 6,000 rpm, indicates larger than standard injectors are likely.thats a verry interesting point, what would be the easiest way to check this out
Fix the tune and it will make a bit more max power (over 300 rwkw), a heap more average power (particularly in the all important 4 to 6,000rpm range) and it will be much faster and more consistent down the ¼. thats the kind of enthousiasm i like to hear
drag-on, you definately dont have a stock ECU.
I can assure you of that, and likely hi-flowed injectors or slightly bigger ones... so it all looks factory... but it isnt :D
Get a pic of the inside of the ECU for us
yeh mine made 254 and went bang after 3 months but that was due to bad tuning aswell but....i know theres a dude here in sa making over 300 on the stock internals and has done for a while
Yes Freebaggins old 33 was making slightly over 300rwkw (313rwkw from memory) for years. :D
Tuning with regular checkups is critical.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
