Bretto - that makes sense now mate. The vct still isn't switching the way it's hooked up, it is just always activated.
Tuitahi - Off the top of my head that sounds right to me. Also have to change one other wire, it's for the power steering. A bunch of other wires from the z32 ecu become redundant.
I do have all the pinouts, i will put it up today/tonight sometime.
Sorry, heaps busy this week. :iluvff:
Cheers
exactly. like i said i dont know this sort of stuff to well so i was hoping it made sense. the only thing that we were a bit unsure about is that my battery went flat on sunday (got the car back friday night) and really the only difference that has been made since swapping the blocks is that the vct is wired into the fuse box to the ignition. any thoughts on whether that could possbly drain the battery??
i went to mercury website and there was no advertisment of re-maps,
i was previously on there site a month ago and found there pricing and everything on it but now its gone >_<
i might hit up google and find those pin-outs and have a sus
so you obviously didn't see the link in my post above yours?
http://www.mercurymotorsport.com.au/produc...nedit/index.htm
ahaha i saw your link but didnt click on it
i searched there site yesterday ! obviously not quite enough
thanks mate but i seen it doesnt say anything about z32 ecu's..
so once im finished all this will it pretty much be a rb25 ecu in the z32 casing pretty much? thats simple terms of course
One would assume that if they have tapped into an ignition switched power supply then it should not drain the battery. However it does sound a bit suss that the battery started going flat after this wiring had been done. Get someone to double check that it is not hooked up to a direct feed from the battery.
Ok so with the wiring for the z32 ecu a bunch of wires are no longer needed so don't stress about them.
Z32 ECU REDUNDANT WIRES -
6
8
33, 34, 35, 36, 37
54, 55
57
102
111
Z32 ECU CHANGED WIRES -
Injector and ignition coil wiring. (double check, triple check, get it right)
19 and 34 need to be swapped over. (power steering switch)
R33 KNOCK SENSORS -
The easy way to do it is just hook up only one knock sensor.
If you have a cro or multimeter you can rev the engine and check which knock sensor puts out the higher signal, then connect that one to the z32 ecu. Or just use the one closest to the firewall.
AUTO TRANS?
Dunno, never tried it on an auto. Feel free to have a bash.
Edited by TSL
It does not matter if the ecu is auto or manual. The hardware is the same, only the software is different. So you can use a manual map in an auto ecu and vice versa.
What i was saying before though is i haven't seen this ecu swap done on an auto before. I'm not really sure if the z32 ecu would communicate properly with an r33 auto trans.
Oh and of course while r32 ecu's are a dime a dozen, it seems to be more tricky to find a z32 ecu for a reasonable price.
Edited by TSL
picked one up for $100 delivered, pretty stoked !!
offtopic yesterday i knocked off my boost gauge T by accident and the car remained running perfect ! wtf ! i remember when i first put the engine in i did this and it died right away.. i think i have a leak else where so could my car adapt to a vac leak>?
thanks
yeh i had a think about about s2 and was wondering abit, im running s1 engine off s2 ecu atm.. hopefully il have some before and after results for everyone when this is done, im not expecting gains really just an easier way to live with rb25 interaction ahahah
  • 1 year later...
I just got my RB25DET (series 2) and I was hoping you could help me with some questions.
My Skyline is non turbo so it will be a big step with the RB25.
Now then, my first question is about the gearbox mounts, I hear they aren't the same and I will also have problems with the speedo meter. What do you know about this? Can I use the Xmember of the R33 ??
The second is about the harness, everyone that has ever swapped an engine told me that the harness is the most difficult part of the swap. Do you have the diagram of the R32 and the R33 (still can't find it for the R32) and some pointers on how this is done??
Hope to get a reply from you soon
Carlos Rudolph
