I'm talking performance i dont waste my money on visuals haha and i have no idea why it says RB20e but its THe RB20DET that is in my car not the RB20E
and how can i change how it says RB20E too RB20DET because thats what i have not the RB20e i dont even know how that got there
Edited by CalgaryGTS4
https://www.sau.com.au/forums/topic/155935-first-mods/#findComment-2899024
It shows we are noobie posters...
It auto modifys or you can get custom ones (depending on if your know the Mods or donations etc)
I hear money makes them happy.. and beer or burbon
https://www.sau.com.au/forums/topic/155935-first-mods/#findComment-2899096
to change the thing in your avatar:
go to "my controls", "edit profile information" then type what you want in "Custom member title".
as for mods, the most important mod to do before anything else is exhaust. there is no point putting more air in if it can't get out. try to go full turbo back, or at least cat back. then go air filter. then you can put a touch more boost in, but don't go above about 9psi on the stock cooler in summer.
https://www.sau.com.au/forums/topic/155935-first-mods/#findComment-2899202
mmm 300hp = mods ive listed with upgrading turbo option and an aftermarket ecu, that should give u a nice power figure as well as handling. ur prob lookin between 4000-7000 dependin on what brand mods u buy.
https://www.sau.com.au/forums/topic/155935-first-mods/#findComment-2899486
fast = expensive.
"cheap performance" is a bit of a myth. and 300hp = 220 kW (get metric, buddy), read the 200kw rb20 thread. over 100kW/L...
(yeah, the imports are 'cheap performance'. 160 kW from 2L for under 15k, AND 4wd... is pretty good value for money).
spend some time searching the forums for more budget upgrades first.
if you really want the power, you will have to run big boost, huge rpm, or more cubes (I vote 1 AND 3).
Have some fun with the car. Play with the 4wd (r32 is ok) so that you appreciate the handling difference. Then look for upgrades. "First Mods" - like I said. search the forum. exhaust, intake, handling kit, then start looking at more dollars and more individual choices.
--ebola
https://www.sau.com.au/forums/topic/155935-first-mods/#findComment-2899629
lol ok well it all depends on what particular mods and what brands ur gonna buy. it could cost u around 4000-6000 just for parts plus dont forget i only listed a few mods u still need the supporting mods like fuel pump, fuel reg, injectors, etc its best if u find out exactly what u want and then research different models, makes and prices and then purchase them according to your needs and funds.
https://www.sau.com.au/forums/topic/155935-first-mods/#findComment-2899642
http://nissanskyline.6te.net/tuning_GTST.htm
check that website out its got a budget guide on how to acheive the power level u wanted without hassle. pretty easy i say especially if ur uncle is a mechanic and ur gonna get free labour following this guide shouldnt cost u much as it uses second hand parts from later model skylines which are ideal upgrades for the r32's.
https://www.sau.com.au/forums/topic/155935-first-mods/#findComment-2899737
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 馃槈. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 馃槏.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 馃檹 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 馃槈. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 馃槏 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
