Hi all, Just cleaning out the shed, Can post the smaller items if required or Pickup, Lismore, NSW.
Nissan Skyline GTR Master Cylinder brace R32 $90
Sold the car so no longer needed. Used to brace the cylinder against the strut tower to improve brake feel/reduce flex. Sort of a race mod really but is anodised blue and looks cool too. (-:
Nissan Skyline GTR Master Cylinder R32 $90
Was Removed from a crashed GTR (NOT crashed due to brake failure) as a replacment for mine but it turned out to be a leaking ABS unit... so since the car is now also sold i no longer need this.
Nissan Skyline GTR coil packs R32 X5 $60 or $15 each (4 left)
Car was upgraded to splitfire coils, one pack got lost somewhere so there are only 5 left, maybe good for a 4 cylinder coil upgrade? (for sr20 etc?)
2X airpods without filter elements, generic/no brand, $10 for both
Sony Xplod Head unit and Stacker + Cadence Equaliser, with wireing, connections, cables, brackets etc. $280 the lot. Was working perfectly when removed from a car prior to sale, new car had decent audio so i have not used it again. (from memory the stacker alone cost over $500 new... ><)
Just email me at [email protected], PM here, or call me on (02)66333131 (Martin, best after 6pm)
I think my prices are reasionable but i am open to offers.
Thanks for looking,
martin
Edited by mmarschall
just curious are 32gtr coils the same as series 1 gtst? both external ignitors? will the just fit in? ive got the 32gtr head but if i can keep the coils i got then will be alot easier
ben...
Hey, sorry, im not sure about gtst coils, i think they may be different, maybe someone can answer you question in a different section of the forums? tech stuff?
the brace bolts to the cylinder itself and existing holes in the strut tower which is just infront of the cylinder.
thanks for the interest,
martin
  • 4 weeks later...
Bump, and decided to sell these too:
2X willans harnesses removed from my R32gtr before compliance. $200 the pair (or make an offer)
  • 5 months later...
  • 6 months later...
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
