Item: 1993 nissan r33 skyline 4 door 5 speed manual gtst
Website: http://www.skylinesaustralia.com/forums/in...howtopic=154238
Item Condition: great, just finished build up
Reason for Selling: i only get to drive it once a week due to work and my daily drive has had it
Price and Payment Conditions: $21000 ono with safety cert(to be obtained once deposit taken)
Extra Info:
Pictures: yes at http://www.skylinesaustralia.com/forums/in...howtopic=154238
Contact Details: mob 0439719822 or email [email protected]
General -
1993 4 door gtst
5 speed manual
85xxxkm
paging alarm system
major service will be done apon sale
only arround 10xxxkm done in aust as it's been off th road for mods
balance of rego
The body -
custom purple with blue pearl
custom side skirts and rear bar
aftermarket front bar obtained through custom carbon
custom front guards
series 2 rear tail lights
aftermarket front grill
custom bonnet (all metal not defectable like carbon)
carbon fibre look mirrors
custom graphics
The interior -
combination of white leather/vinyl/and paint
leather roof lining, dash, door trims, centre console, steering wheel (issotta) gear and handbrake boots, rear parsel shelf and a few other bits
white vinyl boot install, sub box false floor/walls ect
white/blue paint dash cluster and a few other bits
The sound system
Clarion touch screen head unit (flod out tv, cd, ect)
luxun dvd player also plays mp3/mp4/cd
alpine type r 6.5 inch front splits
alpine 6.5 inch type s rear splits
3 12 inch alpine type s subs
alpine 4 channel v12 amp (bridged running front splits)
alpine mono block 800w rms (running 3 12's supplying approx 1350wrms)
fusion capacitor
Mechanical mods -
hybrid front mount intercooler
apexi avcr
xforce stainless exhust including front pipe
heavy duty clutch
jjr oil cooler and oil filter relocator
hks pod filter
dredd racing cold air box (encolosed pod filter making it legal in qld)
autometre colbot gauges 5 inch shift light tach, oil temp oil pressure, water temp air/fuel ratio (these 4 mounted in dash above glovebox)
Wheels tyres -
18inch speedy lite 7's i think
6mm spacer plate on front
235's in great condition all round
may consider trades with cash my way or straight swaps
More pics in the above links to the qld for sale section
https://www.sau.com.au/forums/topic/155947-fs-1-of-a-kind-4-door-skyline/
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
