  • Replies 72
Posted Images
front: 20mm id, 24mm od (and quoted as 192% stiffer than stock) hollow.
rear: 25.4mm id, 30mm od (and quoted as 162% stiffer than stock) also hollow.
both are not adjustable.
By my rough as guts calculations:
I have assumed they are just torsion bars. spring rate for torsion bars varies with the fourth order of diameter ie mm^4. But it is a long time since I have been to uni, so I may be forgetting something....
Anyway the numbers are:
Front
Cusco 24 od, 20 id. mm4 = 171,776
Whiteline front 22 od. mm4 = 234,256
ie Whiteline stiffer by 36%.
Rear.
Cusco 30 od 25.4 id. mm4 = 393,769.
Whiteline 24mm od. mm4 = 331,776
ie Cusco stiffer by 19%.
But that does not take into account any adjustability in the pick up points on the lever arms....
hmm, interesting. so perhaps I'll be better off keeping my rear whiteline and just setting it to 'soft'. but I am keen to get the cusco's even just for the fact they are a fair bit lighter.
for my reference page for swaybar comparisions,
http://www.whiteline.com.au/docs/bulletins...d%20Swaybar.pdf
old thread thats been around for years but is very useful.
http://forums.bimmerforums.com/forum/archi...p/t-334213.html
Edited by URAS
I scanned it from the 2007 dealers catalogue.
salad, the cusco bars are not adjustable. but it doesn't worry me as I have so much adjustment everywhere else! one less thing to play with is almost welcome!
well back to the roll centres.
moon face have a few different options. from replacement arms with their adjuster in it (from what I can tell) to just the adjuster, down to spacers, and sleeves. costs is from around $900 down to like $200.
so dave, buy some mate, try it out, tell me what you think! lol
cheap way:
http://www.moonface.co.jp/mfr/roll/rollmain/index5.htm
rear "pro" kit
http://www.moonface.co.jp/mfr/roll/rollmai...ll%5Bpro%5D.htm
rear kit
http://www.moonface.co.jp/mfr/roll/rollmain/index4.htm
rear pro kit (no arm)
http://www.moonface.co.jp/mfr/roll/rollmai...ar%5Bpro%5D.htm
regular kit
http://www.moonface.co.jp/mfr/roll/rollmain/index2.htm
front kit (doesn't list 32 GTR though, just GTST)
http://www.moonface.co.jp/mfr/roll/rollmain/index.htm
not sure about the difference between the kits. I will find out though. if I get them I will just buy from japan. works out better for me that way.
I think I will give the rear spacers a go first up. See what it does. May even get to back out some rake angle again. Woo hoo.
With the spacers you don't have to press the ball joint out of the arm hence they are cheaper/easier to buy & fit.
Also I thought (Probably wrong again) that the blue spacer was the only one available for the front of the R32 GT-R.
Edited by djr81
cool. very interested to see how it goes. let's keep this thread going so hopefully we can all take a step forward. let me know what they cost too if poss. :)
Who's the aus distributor for moonface? I like the look of that stuff as i have already gone to the trouble of replacing all my rubber bushes in the suspension arms and don't want to go the next step of full adjustable arms.
Drift shop Australia. Believe the blokes name is Costa.
www.driftshop.com.au
But as I understand it he is just starting on the Moonface gear. So an email may be the best bet. Just get in line, cause I have first dibs. :)
Edited by djr81
    • Is the 650rpm idle on the rb25det neo for stock cars only? I've never had my car before and after tuning it to idle at 650rpm when cold. Always idle's cold around 1100rpm, and then drops to about 900-950rpm. I've heard the r33 gtst's idle there.
    • Series 1 RB25DET 5 speed gearbox, push type, 1st and 2nd gear syncros worn, may need bearings. Comes with quick shift, Tomei gear knob, release fork, bearing carrier, master and slave cylinder. $850. Cusco Super Single clutch,assembly, 225mm, used, comes with a Direct Clutch solid centre 5 puck ceramic clutch plate. $290. RB26 cams used, excellent condition. $280. HDI GT2 intercooler, excellent condition, has 3 inch piping welded to inlet and outlet. $250. All items located in South Eastern Melbourne. Please PM me if interested.
    • Hi all, I’m currently running a str pipe hi low hks exhaust and downpipe. Was wondering if I change out muffler to a titanium one will it change the sound of the exhaust? Plus I have always liked the look of the titanium pipes … anyone have recommendations to one?    side note already have titanium intake pipes.
    • I looked up my other car that is a R33 GTST series 1.5. Anyone able to confirm what a Aero Form Bumper is?     (1G) 2 Door Coupe; (2GK + 11V) RB25DET; (4B) 2WD HICAS; (7F) 5 Speed Manual; (14G) Super Fine Hard Coat; (15U) Large Rear Spoiler + Aero Form Bumper + Rear Wiper (Aero Selection)
    • Ha ha, all good! I've almost caved in and realised I'm buying one.  I know myself well enough by now that I will start chasing ADHD butterflies half way through building it and not finish it so I'm better off spending the extra money buying one instead of making one just so I can get into straight away.  I would very much enjoy making one as fabrication is probably a strength and definitely a passion but I don't want that to be at the detriment to the car I'm ultimately building it for! There's some pretty good ones around for ~$1100 at the moment so I think I'll just go that way.  At the end I sell it or as mentioned, get another project to make further use of it! Thanks gents.
