just asking for my cousin who has an old skool bluebird (no idea wat year or model)and reckons the r31 brakes and his brakes are the same anyways just wanted to find out is there any brake upgrades available for r31 silouette skylines?? cheers in advance
https://www.sau.com.au/forums/topic/155964-r31-brake-upgrade/
dont bother with the stock aussie non floating intergrated hub brakes- they are shit. get yourself a set of GTS/HR31 front struts or a full s13 front end, then you can use the later model 100mm spacing calipers.. r33, r32, z32 ect. obvioulsy if your using a 5 stud rotor it wont fit, so you can either get it redrilled to the 4 stud pattern or use s14 hubs (if your using s13 gear) apparently Z31 5 stud hubs fit the HR31 stub axles but I dont know for certain. another alternative is to use brakes that are already 4 stud, such as r33 non turbo.
Guest
