Currently Playing
kralster
 Share
  • Replies 838
Posted Images
currently playing. time crisis 4 PS3. should I be embarresed? :P but hey it was a gift! and actually quite fun. though I really wish the guns had recoil like the arcade ones used to, or at least rumble/dual shock. that would be nice. :D
ive been thinking about gettting tc4, i could finish tc2 on once credit back in the day lol
how accurate is the gun?
yeah it's not too bad. you calibrate it each time you start the game. you can chose 2 point calibration or 5 point. I always do the 5 point. i'm playing on a 46" sony XBR lcd and the sensor cord isn;t long enough to span the width of the TV but it's not a problem.
I tried the FPS part of the game last night. the controls seem so akward at first but it's actually not too bad once you get into it. :dry:
well COD4 runs aswell on the mac as it does on a PC
im on teh minimum X1600 card specs - un-upgradeable as its my laptop
get anywhere from 20 (with heaps of people at spawn) to about 75 fps
ran these commands in console to up the fps - works well:
/com_maxfps 125
/cg_fov 80
/r_drawdecals 1 (0 is off - no papers flying about)
/maxpackets 100
/snaps 30
/r_drawsun 0 (sun off)
/cg_brass 0 (shell ejection off)
/cg_drawfps 1 (shows fps counter in top right corner)
/r_multigpu 1 (on, increases fps even if only one gpu)
just finished GTAIV, talk about the most boring game of all time. at least now i never have to put it back in the xbox.
currently playing...
Far Cry 2 PC - It's ok but not that great stupid little things make it frustrating.
WAR - good fun still i'm only level 11 but it's fun with mates!
currently playing
Fable 2 (x360) Absolutely loving it.
finished sw force unleashed in 2 days prior to purchase of fable.
Will get far cry 2, dead space, fallout 3 and gear 2. Man the 360 is awesome. Meanwhile my ps3 is collecting dust unless i am watching dvd/blu-ray
Haven't played any games on a pc in years. If Star Wars: The old Republic mmo is only pc looks like i may use a pc again.
went and saw max payne the movie last week.. since then i have reinstalled and completed the first game and i am currently playing max payne 2.. they are both still awesome seeings at the first game is roughly 7-8 years old and the second game is 5-6 years old.. much fun :)
 Share
    • Brand new r34 gtt box
    • What is the go to gearbox these days for a RWD RB? Back in the day VG TT boxes were cheap and strong. Seems they are as expensive as an RB25 box these days. What are the options without remortgaging the house?
    • Define "Nissan big brakes". You just mean standard R34 4 pots? And...it's not even the offset you need to worry about. It's really a detail of how much clearance there is between the caliper and the back of the spoke/face, which is affected more by the design of the spoke than it is by the offset. If you think about it....take any wheel, say a 19x8 that does fit and clears the caliper. Then add or subtract an inch of wheel on the outside, without changing anything else. You have changed the offset by half an inch, but not changed the clearance situation at all. Same for if you add or subtract an inch from the inside edge. The way for you to work this out is to take a wheel off the car, grab a straight edge and a ruler or two, and start to measure the distances from the wheel mounting face on the hub to the outer face of the caliper, and the outer diameter (that faces the barrel of the wheel) of the caliper. Armed with these dimensions and any other measurement that grabs your fancy while you are there, you can then go to the seller of the wheels and do the reverse measurements from the wheel's mounting face and see if there will be clearance to the caliper. There really should be. I have 17x8 RPF1s +35 clearing the caliper face by a finger tip. Those wheels do have pretty thin spokes with some curvature.... but then so do most wheels to suit Jap cars.
    • So I’ve got a r34 sedan that I managed to get green stickered, meaning I need to go through government approved wof station for my car to be allowed back on the road for some reason my car is certed for 19x8 rims.. I need these wheels  does anyone know what offset will be fine to clear Nissan big brakes? I saw 35et for sale near me, I can’t drive the car to test fit or risk being fined ..   I searched heaps online couldn’t find anywhere..
    • Okay, with all that being said about sloppy blowing from twins, I happily acknowledge the superiority of a single turbo setup on the RB; however, I still plan on double trouble.  I know the -9s were quite popular for some time because they seemed to meet that sweet spot between the -7s and 5s, would introducing VCAM and/or stroking to 2.8L provide the additional displacement/flow to push twins closer to the 500-600 goal?  Does it make more sense for a daily to just do an engine overhaul, slap some -7s on it and enjoy a bit more reliable power?  Has anyone driven a mine's overhauled and tuned engine?  I know they certainly don't approach the power numbers that you drag monsters do down under, but for daily street usage, I just want it to be fun and healthy.
