  • Replies 838
Posted Images
Currently playing saints row 2 & empires total war for PC
Seeing how everything goes, if RE5 don't get ported to the PC in the next 6 month or so, I would have to fork out for a PS3 just for that game, dam Capcom & their anti-PC releases :D
EDIT: seeing how long it took for them to port RE4 to PC & the horrible port quality, guess I need to go console... :D
Edited by Mayuri Krab
  • 3 weeks later...
http://baz47u.mybrute.com
Ok so after playing this game for a bit i have learnt some new info...
the way the game is you create a character which you train/fight and eventually get extra weapons/animals/etc. Use link provided above
you can participate in tournaments (not sure how it works yet) which then gives you a ranking etc
fun game to play when you have nothing to do
enjoy
LEFT 4 DEAD... best online game atm the teamwork and cooperation needed is totally different to any other game help your friends or u all perish yay
This by far is the funnest and funniest game ive played online!!!! and am addicted to it!!
+1 for bf2
awesome game play although nicer graphics would be great
running top graphics and 3d but still looks dated
i'm over hackers and noobs who punish you for a team kill when they run out infront of your vehicle, drive over a mine or walk into your claymore.
but nothing better than a friday night, get 2 6 packs and an esky - sit it next to the pc - god i'm a geek...
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
