  • Replies 838
Posted Images
hrm... good ol' cs 1.6 :P used to be in one of the top ranking perth clans..was awsum (played mainly on 3fl)
now i just play whatever i want.. used to play cs hardcore, and halo 3 hardcore... but the only game i've played for such an extended amount of time?
.....WoW...... *hangs head in shame* i've quit like 5 times SERIOUSLY!!!!
but i play dawn of war 2, css, left4dead i dunno... most games i have hahaha
Been thinking of getting guitar hero Metallica. Whats it like compared to the previous one ^^^
Similar. But with a lot of Metallica music in it :)
'tis pretty cool. Got it from the US for ~$60AUD, add in a second kick pedal (I have the RB2 twin setup) and all is good!
Lots of great tracks, fair few that are not from Metallica (although they have covered some of them) and some damn hard one's.
Has some nice extra movies in there as well which is pretty cool. Lots of "extras"
Bitch thing is that you can't transfer the tracks to GH:WT. You need to change games if you want to play different songs.
Get it if you like GH and Metallica. It is worth it.
currently hooked on The Sims 3 :cheers:
When Sims1 came out i got hooked on it pretty bad. Then one day i was making the guy clean his dishes and work out on the weights.
I looked around at my dirty house and my fat gut, and realised the true irony of such a game.
I never played it again. HAHAHA :laughing-smiley-014:
PS. What front bar is that in your pic, typevu?
lol if only doing it in real life was just as easy as clicking the mice and fast forwarding the time!
The front bumper was an optional bumper only available to 40th Anniversary built R33's(late 97 to early 1998).
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
