Thanks Karen :iluvff:
I have a guy organised to pick it up with a ute and engine crane but his ute is a bit dogey, meaning that it conks out for no reason whenever it feels like it, does anyone know of someone who could deliver it to my place and unload it?
https://www.sau.com.au/forums/topic/155976-r33s2/#findComment-2905124
I got my old engine from the gold coast to my place for about $80 I just rang a towing company and they handled it no worries
https://www.sau.com.au/forums/topic/155976-r33s2/#findComment-2905281
Thanks for the call Dan, and as you know it is sitting in my garage, so the VY made it after all, in its first run for 3 months, Dave is great guy to deal with, and I wish we could of talked longer, many thanks for the extras!
https://www.sau.com.au/forums/topic/155976-r33s2/#findComment-2912725
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
