sup
forgive the stupid question/noobness. but do rwc joints usually pick on such things?
i went today to about 7 places and they all gave me the same farkin answer "come by tomorrow or wednesday"
anyway, at one place the guy just took a very quick look at the car and spotted these 3 unroadworthy things.
going tomorrow to a...umm...a..."special" rwc place :P:) and get this over with but just curious...
bit tight don't you think?
dirty headlight
don't know if you can see it but the very thin line under the p-plate. bottom left corner of the p-plate (dirt)
dirt blinker
https://www.sau.com.au/forums/topic/155989-do-these-look-un-roadworthy-to-you/
as long as they work i dont see anything wrong.. If a windscreen is chipped or cracked its un roadworthy or moisture in headlights/tail lights
they all work. the line on the windscreen is just dirt that doesn't wanna come off too easily. whatever that is on the headlight, it's inside but it's just as good as the other one when light is actually turned on...
Those headlights are pretty bad and I have seen various EL Falcons, etc, fail roadworthy in similar or worse condition. As previously posted, try to use cutters and buff the headlights, but remove them off the car first and take care not to burn the plastic.
Windscreen can simply be polished off, by a professional glass polisher.
Tail light is tricky as you have a moisture issue, thus have a build up of dirt/grime inside the light assembly.
Think yourself lucky. Many years ago, to get a roadworthy, you HAD TO replace the windscreen. Without any form of measuring equipment, they always deemed that a (used) windscreen did not meet the standard for light transmission.
yeah i guess it's not all too bad but remember this was just a very quick look it wasn't an actual inspection.
i went this morning to a different place, didn't notice these little things but came up with this list:
l/h outer e/v boot split
r/h outer e/v boot split
radius arm bushes
he said it would cost $275 to replace these with new ones. does this sound right? already wasted $100 on the inspection.
still cheaper if i was to get a "special" rwc :kiss:
Edited by R-SPEC
what the hell is an EV boot.. a CV boot?
try ringing Chris @ Centreline for a 2nd quote 94692914. They're just off Mahoneys Rd and won't rip you off.
PS $100 is a ripoff.. I hope that was for 2 x $50 inspections at different places. Don't forget that if you take it back to the same place within the 30days you do not have to pay another inspection/RW fee.
how does that work? did they have to fix something or put in whiteline bushes? I think from memory their alignments are $90 for 4 wheel.
Edit: There you go, Michael said a camber kit is about $300 or thereabouts with an alignment.
Also it was probably a Whiteline kit, and Centreline usually charge less than if you buy direct from Whiteline.
You can have a look at one of Sydneykids threads to compare prices for the kits.
well being that I wasn't there and don't know the full circumstances of the problem, I can only suggest you look at the receipt and give Chris a call if you don't understand what was done to the car and what you were paying for. Chris has always justified what he has done or what needs to be done to our cars and the price/quote even without being asked and to the point of him giving me back the broken parts without asking for them.
To me it sounds like something else was obviously fixed/replaced and Justin isn't clear on what he was paying for.
hehe
nah dezz was with me at the time cause he got some work done on his car earlier that day.
aparantly... the camber on both wheels on the passenger side magicaly changed cause i had a big side on accident.. evan though theres no damage on my car... or on the wheels.. anyways
he goes "its going to take 2-3 hours to fix and cost a few $100"
and 30 minutes later the camber had the correct settings again.. and i was down $300
he evan said to dezz "your friend must of had a big accident"..
my theory is... 2 ppl installed all the suspension stuff originaly.. 1 on each side...
the guy who did it on the passenger side didnt do the camber properly or something...
radius arm bushes
still cheaper if i was to get a "special" rwc :ninja:
:rofl:
Agreed.......
Sorry Justin, i still find your story hard to beleive. I've been to Centreline, many times for different things, Chris is currently sorting out a set of coil-overs for my car, and i have had nothing but top class work at good prices.
It's strange how almost every person that works on your car f**ks it up or rips you off :) ; even though many others have never had issues using the same business.
If you still have concerns/issues, (and you obiously do) why not approach Chris and ask for clarification on what was done in those 30mins :huh:
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
