Thinking about selling my onevia, don't have time to have the same interest in cars as I used to/would like to. Also not practical with my studies... part time jobs don't pay well and gotta start saving for a house deposit...
Took ownership of this car over from HUSTLA on nissansilvia.com as a ca18det silvia about a few months back and started throwing parts at it first thing I did was turn it into a onevia cos I love em (not in front end accident)
This would be great for a track car - some mild engine work and tough exterior... this car was being built to slide but have lost interest
Body
GP sports front bar
Genuine nissan factory option plastic side skirts
Genuine Supermade fixed headlights imported new from japan
Metal bonnet with genuine masa bonnet vents installed
Rolled and flared rear guards
Standard front guards
Boot holes welded and smoothed
Arial removed, welded and smoothed
Currently matte black
Engine
Ca18det manual
New Xtreme drift series clutch
HKS mushroom pod (mad as flutter)
T25g turbo
Metal head gasket
Front mount intercooler
Bosch 040 fuel pump
Full 3" exhaust system with Jun BL rear muffler mounted near diff and twin straight pipes from rear. Rear section can be interchanged with another diff back pipe and muffler which passes regency
Turbosmart type 3 supersonic BOV
Alloy radiator overflow bottle
Battery relocated to boot
air con removed (still here and included in sale)
Interior
AVC-R limited edition black one (not yet installed - in box like new)
Full lineup of autometer guages (not yet installed)
- 52mm electronic water temperature
- 52mm electronic oil temperature
- 52mm electronic fuel pressure
- 60mm electronic oil pressure
all guages have never been hooked up so as new, come with din holder for 3 52mm guages and GReddy pillar mount for 60mm one
sr20 front seats
carpet removed (still here and perfect condition and included in sale)
Aftermarket steering wheel, similar offset to a nardi deep corn
Aluminium gear knob
Alpine 6.5" splits with external cross overs in front doors (not installed yet)
Boost guage
Turbo Timer
Fire extinguisher
Immaculate black dash
Suspension and Rolling stock
polished sr20 stockies with good tread
GAB super sroke suspension
Cusco OS front strut brace (not yet on car)
Cusco OS rear strut brace (not yet on car)
Extra's
Endless SSS 0-500 degree rear brake pads in box (best streetable pads before track level)
Full set of stock supspension
sr20det fuel pump and cradle setup
All the air con stuff
All interior pieces that have been removed including carpet - all in exceptional condition
Welded 3x2 bolt lsd (if you want to skid it)
6 driving lights so you can choose your own headlight style
prob heap of other stuff too - if i find something here i don't need it goes with the car
Genuine TBO sideskirts (modified)
25mm wider vented front guards
Milage
Says 69thou or something, not sure on the legitimacy of this but its one of the cleanest s13's I have seen chassis wise
Probably forgot more but its been a long day
12.8k ono
can negotiate without some parts to lower price
cheap as all hell now, begging to be slid
http://i66.photobucket.com/albums/h252/1at...-01-07_13-4.jpg
http://i66.photobucket.com/albums/h252/1at...-01-07_13-2.jpg
http://i66.photobucket.com/albums/h252/1at...02-01-07_13.jpg
http://i66.photobucket.com/albums/h252/1at...12-12-06_16.jpg
http://i66.photobucket.com/albums/h252/1at...-11-06_16-1.jpg
last pic just shows rear flares
comes with fresh 6 months sa rego too
may trade for cheaper car + cash
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
