Car also includes:
Pioneer Mp3 head unit
Turbo timer
Boost gauge
Boost controller
C's short shifter
Turbosmart BOV (Plumb back or Atmo)
K&N Pod filter with custom made Perspex cover using the original snorkel for cold air intake
4inch Cannon
Alarm
Black AXS seat covers
All cables installed for sub and amp
Custom blue paint job
All servicing and work done at Autosport engineering at Kirrawee
Manual
Kilometres 107,000
Reg Expire JUL-2007
Regretful sale only due to work car, More pictures can be sent on request.
* Car has key mark & paint damage on front bar(can be repairded on request)
*************$12,500 ONO
Sydney - Hurstville
Contact
Steven
[email protected]
0404 801 809
Edited by faz
https://www.sau.com.au/forums/topic/156036-sold/
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
