  • Replies 56
For 1 week only... $20,000 firm with stock rims, moved house and changing jobs would like it gone quickly. Ph: 0414 224 905
Edited by nismomiles33
  • 3 weeks later...
Will separate engine, complete fan to flywheel $9500. Can negotiate on price depending on what bits buyer doesn't want. This engine will be perfect for track work, has the power to easily run 10's or better in a VL or something setup well with a auto behind it. This engine would cost $18-$22,000 to have built, and will be inspected and freshened if need be on sale for buyers peace of mind..
Mate sounds like your planning to try knock it.. It has a full alarm system which is noise sensitive etc and seperate engine immobilisers. Im in Ballarat VIC.
not at all mate, ive just had issues with people breaking into my cars & its one of the first things i look at when buying an import, am interested however
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
