Installing An Amp, Do You Remove The Positive Or Negative Terminal?
How do you guys install your amps and wiring, do you remove the negative terminal or positive terminal, or both? Personally, I just remove the negative terminal and never have any problems with installs
Edited by sumguy
I believe negative is safest, so if you are using a spanner and it hits the body work, you are connecting earth-earth which is safe, no spark. If you are loosening your positive with a spanner, and the other end hits some metal, you'll short & spark!
This is why when you change a battery, its negative off first, connect negative back last.
Just make sure you do the engine bay last and you run the power cable from the fuse holder to the amp then from the fuse holder back to the battery and you shouldnt have a problem allowing you to test the head unit/DVD while your working on it. :ninja:
    • There was a thread on here when it was set up for the Bathurst 12/24 hour race a while ago then went to giant then to Jason’s who I bought it off   has some cool shit and is old school cool
    • I would call it the "manifold coolant outlet" or something like that.  If you know the dimensions you can just get a bit of mild steel (or stainless) pipe that is the correct size, bead roll a hose retaining lip into the end of it and bash it in! Or, get fancy-  https://boostdoc.com.au/products/rb25-neo-billet-top-hose-outlets?srsltid=AfmBOopjNetVaMphRC0x44Er2jwO2k5vPp-4AGG5Bd285Ah0SsXXGk3e
    • True....I've not done a bearing in a borrowed car yet, but I've sure as hell killed a clutch in one   What's the car's history? Looks like a fair bit done to it already
    • For $2m you could grab Brockys sons daily driver AND a R34 GTR VSpec
    • Help! Can anyone tell me what this part is called? Mines a rusted mess as you can see in attached photo and I'm struggling to find a replacement for it anywhere because I simply don't know what to search up. It's on my intake manifold and I believe the top radiator hose attaches to it. If anyone also knows where to buy one from that information would be greatly appreciated aswell 😊
