Up for sale is our R32 GTS-t, built by TRIAL tuning house in Japan, there isnt much this car does not have!
-RB25DET, the motor has been built, not sure on exact specs, I know it has metal head gasket, after market camshafts, forged pistons, ported head ect.
-RB25 Gearbox with OS Giken crossmission gearset
-OS Giken twin plate clutch
-KAAZ 2 way mechanical diff
-TEIN RA coil overs
-Adjustable castor rods
-TRUST TD06-20g turbocharger kit
-TRUST intercooler kit
-NISMO 555cc injectors
-NISMO fuel pressure reg
-SPLITFIRE coils
-BILLION aluminium radiator
-R33 GTR BREMBO front brakes
-R32 GTR front guards, bonnet and bumper bar
-WORK Meister S1 wheels
-TRUST 80mm exhaust system
-BRIDE drivers seat with Willans harness
-GTR passanger seat
-CUSCO roll cage
-GREDDY guages x 6
-Autometer RPM guage
-AP Engineering APEXI power FC
-HKS boost controller
-APEXI RSM
-VEILSIDE cluster
The car makes 280rwkw on a lowish 1.2bar, it has been very reliable and does not miss a beat, the car has current Victorian registration untill March 2007, it will be sold as is with no RWC if sold in Victoria for obvious reasons.
The car is now plain black and has no stickers on it.
Asking price for the car is $19000.
PMs will be replied to or you can E-Mail direct at [email protected]
Edited by Creatd Motorsports
https://www.sau.com.au/forums/topic/156108-sold/
rb25 engine but rb20 gbox? i can understand if it has an rb20 gbox behind it if its got an os set in it... however since when is an rb25 pfc produced by AP?
do you maybe have it around the wrong way? rb20 engine and rb25 gbox with os set?
https://www.sau.com.au/forums/topic/156108-sold/#findComment-2906408
no, trial built RB25, RB25 box with os giken internals. PFC is AP engineering and runs "psuedo" d-jetro. i think typo on box.
Edited by URAS
https://www.sau.com.au/forums/topic/156108-sold/#findComment-2906738
Guest
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
