I read a huge article somewhere on the net not long ago i think from memory on autospeed.com, bu tnot exactly sure, but had really comprehencesive write up on the differences between the normal GTR and an N1. I guess the easiest way to pick the N1's where that the majority if not all i think where white and the front lower lip extension was NOT painted. It came with small extras like strut bars front and rear, slightly uprated brakes, and from memory slightly better turbos? If i find the article i'll post it for ya.
- Look for carbon fibre diffusers front and back
- No stereo, and no aerial (replaced with rubber blanking plug)
- No A/C on climate control, button blanked out
- Oil coolers for both engine and transfer case
- N1 vehicle ID plate
can't think of anything else off the top of my head.....
depends on the model as to what the differences are. but basically N1 was designed for "production class" group N racing. They were made in R32 (228) only one in Australia R33 and R34
The difference are: (someone will blow me out of the water here as I am not sure of all the differences)
base model is usually a V-spec but with the following additions at the factory... ie during production
steel wheel N1 turbos
different ECU mapping
N1 water pump
N1 oil pump
N1 block
different pistons and rods
oil coolers for diff, gear box and engine (engine oil to H2O)
no A/C though it could be spec'd up (pannel still there)
white in colour
carbon bonnet on 34
faster sample rate for the ATTESSA
faster sample rate for ABS (no ABS on R32????)
different sacale on instruments speedo boost gauge etc
larger exhaust
under tray and diffusers depending on model
someone must be running one of these in targa, or an N1 replice that could add to this or correct the list steve from justjap or targa
very hard to find out information when you dont speak japanese
this is a copy of imformation I have placed elsewhere
As silly as it sounds Nissan may be able to varify, perhaps through someone like Hornsby nissan, who deal a lot with nissan japan due to the work they do on GTR's (R32 dealer)
Also:
evo-r had one which did not have the build plates on it
Jeff Keyte running one in targa
as is Steve Glenney
AVO in melbourne did a 3L conversion on one
hope this helps a little
Cheers Alex
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
