They do custom? Are they anygood? I thought kmac did dodgy shit that VN owners bought?
Well with a heating torch & a pipe bender you can be your very own custom sway bar manufacturer... Have a look at the current whiteline cattledog. You will see that there isn't alot of science in it.
for some reason i can't find extra heavy duty r32 gtst front sway bars on whiteline (somethnig >24mm) whats the story, cause they have extra heavy duty for r33s etc
anyone know which ones are interchangible? (i know r32 gtr and r32 gtst rears are)
Yeah Kmac do custom...i have them on mine....27 up front atm...and 20 at rear. But they f**ked up the oreder first time....took me 3 months to get the first set. and they were totally wrong, so i sent my original down with the set and they remade them, i still havent recieved my old ones back yet. As for performance, they seem to hold the car well, need a thicker back one i think, but shit house service, and an good bar, i havent used whiteline so i cant compare them.
Oh and i just got non adjustable swaybars too, they do, do some really good adjustable ones apparantly.
Whiteline can make the cars for you, just depends if they want to, in their catoluges they have up to 34 or something mm thick bars. 24mm is the biggest standard line they do though.
I'm looking at around 7/8" or 22mm? soild bar.... Idealy bigger but I need to talk to someone to confirm 1st. Do I just call kmac number on the site? or does someone have hook ups?
Just call the number on the site. I dealt with Kevin, i think he was the manager.
go talk to steve, at pedder maroochydore, he is in the process of getting a custom sway bar made for my bosses daughter's mustang. the one that came with it was broken apparently. so he mite be able to help ya in getting something customized. worth a shot.
Or PM sydney kid on here and ask him if he knows anybody who could maybe help ya since he does all the suspension stuff on here he mite have the contacts you are after.
Edited by 85URK
Steve can go f**k him self, for legal reasons I will not make mention of what happened over the internet, however he better think himself lucky I didn’t take the matter further.
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
