Harry,
De-cat is just a pipe while the cataylic converter is a oval-ish shape. If you're not that bad with spanner, you could remove the 'cat' and see what is inside, shouldn't take more than a hour or 2.
Should the 'cat' actually a cataylic converter, take some photo and write the letter stating you have one and if you feel strongly about the officer's perscptive (spelling?) see the station manager and have it overturned along with proof.
Cheers
Grant
Again, thanks for you advice so far, im really pulling my hair out at the moment so i appreciate it!
R31Nismoid you are always a gun, so your advice/input would be appreciated here...
I am currently thinking there are two possible avenues to dispute this.
1. Since the car was purchased without a Cat & Roadworthy was supplied by his dad's workshop, I can try to contact the previous owner and tell him the situation and request that he pays the $1500 fine, or I will summons him to court. Hopefully he will do the honerable thing and pay the fine otherwise it will be difficult to prove this in court.
2. I can contest the fine through EPA and write a very well written letter explaining that I purchased the car in the current state and that I should not be held liable. Also, how do they know its not a high flow cat? The police officer took a photo of it underneath the car at night for proof but never actually opened the pipe to check inside. For all we know it could just be a high flow cat? The outside of a de-cat and high flow look very similar dont they? Wouldn't it then be up to them to prove that its not a high flow?
I should not be held liable for this and its just so unfair!! I might go and consult lawyer, does anyone know any lawyers in melb that would specialise in traffic law?
In relation to point 2.
How can they prove that it wasn't a high flow from a picture? Couldn't I contest this? Then it would be up to them to prove it?
sorry for the delay - i did see it, just needed enough time to read it all.
I think if you send a letter to the EPA (do you still have a copy of the RWC?) and then also fill out a Stat Dec, then you should be right.
This then puts it back to the RWC issuer, clearly (if what you say is true) then he has attained a dodgy RWC.
If the EPA let you off, i'd leave it there. If not - then go the whole hog on the business that issued the RWC if you ask me.
Giving a cert for something that you then get pinned for really isn't decent for the unsuspecting motorist
Most "decat" pipes I've seen still have the oval shape etc, just nothing in it. So as far as a cop knows there's a cat there and they must assume it's a cat (bit hard to assume it's a cat cover with straight through pipe?).
I am assuming you don't even have the oval shaped housing?
G'day all,
Got a q, If I hand the plates back to vicroads, and sell the car unregistered should I bother writing transfer form or?
Cheers
Grant
Nope - your not transferring it technically, as you could be sending interstate or otherwise.
As far as VicRoads is concerned there is nothing to transfer in that regard :P
When the new owner goes to re-rego then it will pop up with that VIN/Chassis # and will be un-rego.
So long as the buyer rocks in with a RWC, i think thats all you'll need (and maybe they might need to see proof of purchase, best to call VicRoads on that to check)
Ta for quick answer, will give VR a quick ring tomorrow and see what they say.
Cheers
Grant
This could help and im sure it wouldnt do any harm but from the EPA's point of view, you a responsible for your car not the previous owner so really they're probably not gonna care. Also you've got to remember the RWC only lasts for 30 days so depending how long u've had ur car for, its goona be pretty hard to prove that you haven't modified anything in that period of time. Also remember that when it comes to environmental law its guilty unless proven innocent.
What i suggest is you approach the workshop, explain your situation and ask them to at least help you out fixing/paying the fine. Then if that doesnt work you can bring in the lawyers.
FYI: Anyone wanting to hear the conclusion of this story please read the specific thread relating to this issue here:
http://www.skylinesaustralia.com/forums/Pi...15#entry4376815
As far as VicRoads is concerned there is nothing to transfer in that regard :yes:
The seller needs to write a quick letter and sign it saying that they are selling such and such a car (ie. VIN and engine number) unregistered to such and such a person. Otherwise Vicroads will query it when it's time to be re-registered. Same goes for an engine, you'll need proof of ownership (ie. workshop/importer receipt or a letter from the previous owner) to change engine numbers over with Vicroads.
GTR-PWR - RWC period is 30 days. After this has expired - the RWC tester has no liability what so ever. If you got pulled over within the 30 days of the RWC - then you could claim that the car was not RWCed. Keep in mind that if it was a stealth type cat (looks like a cat, but no ceramic monolith inside) - the owner may have not known that it was a de-cat pipe. In addition, 99% of the RWC places do not remove a cat to see if it is real/working.
Ensure that all emissions hoses, systems, tools etc are working and correctly fitted and you will pass. If you have aftemarket management such as a PowerFC, injectors, non-standard turbo etc - this will all be required to be returned to standard. Hiflow turbos can get away with testing because they lookthe same from the outside.
The emissions test is done at idle and at a specific RPM / rev-range using an exhaust gas analyser. It takes about 30 mins. The guys will try to con you into saying that you had mods previous etc to get you in a trap to say that the car was modified. Stick to your guns and says that this is how I bought the vehicle and so forth.
Well I just nabbed yet another EPA notice :)
Gotta love it.
What I did find out, is that if you log a freedom of information thing, you can get the cops name and so on.
So that they can be taken to court if you are wrongly reported.
Something to think about :banana:
Hey guys, just wondering whether it's actually illegal to have an aftermarket bonnet?
Reading through VSI, it sounds like I can legally have Z-Tune bonnet (being of a type offered by the manufacturer for the vehicle as an option for that model or series).
With a body kit, as long as the ground clearance is respected, I guess it is completely legal? I am aiming to get the Z-tune body kit.
I heard something about fibreglass parts being illegal but CF being ok, but might be just a rumour.
VSI8.pdf
CF is the illegal stuff i thought with fibreglass being the ok to use
Either that or its both illegal.
And usually you'll find most stuff isnt true carbon fibre. Its a blend with fibreglass underneath and the CF layers on top :happy:
Hmmm... ok I have to look into it.
Lol... I didn't know that most advertised CF actually had FB in it. Keeps the costs down I suppose. It's friggin expensive as it is.
Well I just read through VS18 and the exact wording that they'll get you on for an aftermarket bonnet is:
"An approval certificate is required for modifications to the occupant compartment and panels forward of the firewall of any passenger car manufactured after 1972"
So I read that as all aftermarket bonnets, guards and front bars seem to be illegal no matter what material they are made from.
ooo that wording means - gotta talk to an engineer i believe, being VicRoads dont give approval.
IMO just keep the stock bonnet, if you get defected, swap it back.
So many laws in this state are bullshit to be honest.
WTF????? That's a shock... must have missed that one somewhere. Has anyone been defected for their bodykit apart from ground clearance?
And why 1972?
G'day all,
I'm in need of a place that does RWC near Frankston (couple of places has tried to rip me off), happy to drive to Moorabbin or Dandenong. Anyone decent would be nice...
Cheers
Grant
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
