The Epa Thread/Roadworthy Thread
Do-Luck
Hi guys
I'm in need of a place that does RWC preferably around Preston area but anywhere decent would be really fine..say about not more than 30km from the city (actually any decent place you know please do advise me)
cheers
Out of curiosity, does anyone know if aftermarket 4WD controllers are legal?
I have not read a law against them (yet) but I'm sure the police may find one if necessary.
Does anyone know a law against adjusting the AWD system in your vehicle using an electronic device?
i got a defect for being to low , on the paper it said adjust it a little more higher thats it. he ticked the box RWC required and it was a minor. Now would i need to go to a workshop and get a RWC or do i just adjust the hieght at home then go to VIC roads and get them to check?
Thanks.
Geraus.
i believe if you change the rails yes
and a fixed back requires engineers also - as you legally have to re-rego it as a 2-seater only - and if you get busted with people in the backseat - god help you :P
They dont care, and for good reason.
In an event of an accident on the passenger side - how do people get out of the drivers?
Its purely a safety thing, and honestly something i very much agree with.
quick question re seats - and sorry I haven't read entire thread only the last little bit cause we're on the topic of seats sorta anyways:
I've removed my rear seats years ago to replace with mdf/fibreglass/multimedia etc and spent a day on the phones chasing around requirements. Finally, the answer was that if i didn't change the metal/structure/parcelshelf or anything existing, then i didn't need an engineers certificate. People have told me i need to re-register but I never have and have been pulled over by cops up to 6 times already this year but nothing, nobody says anything.
do i speak to vic roads before rego is due next time, or remain how is as it can be changed back and not permanent? has it got something to do with the seatbelts if they are removed or not?
Thanks.
Got defected twice this weekend :P one for tyres being a bit too bald and the other for blue parkers. I copped a major for the tyres with RWC needed. Now my car will pass easily except for one thing... is it un-roadworthy to not have a fan shroud? Should i hide my boost controller somewhere? or is that only an EPA thing?
Hi,
I did a search but can't seem to find an exact answer to my questions.
I'm looking at buying a skyline from NSW. The car would have a NSW RWC with it.
1. What do I need to get it registered in my name in VIC?
2. Do I need to get a VIC RWC again?
3. Also, since the car is not rego-ed in VIC, when driving back from NSW with an NSW rego, do I need to apply for temp rego from Vicroads?
4. What should I be getting from the seller in NSW? i.e. What kind of documents?
Sorry for these questions as I'll be relocating to melbourne for work come end June. Thank you.
Hi,
I'm looking at buying a skyline from NSW. The car would have a NSW RWC with it. - If you're going to transfer the rego to Victoria, I wouldn't bother getting NSW one.
1. What do I need to get it registered in my name in VIC? See below.
2. Do I need to get a VIC RWC again? Yes you do need to obtain RWC in Victoria.
3. Also, since the car is not rego-ed in VIC, when driving back from NSW with an NSW rego, do I need to apply for temp rego from Vicroads? Just drive around until you get Victorian RWC and go to Vicroads to swap the plates over.
4. What should I be getting from the seller in NSW? i.e. What kind of documents? You'll need some sort of ownership transfer form and possibly receipt for stamp duty (not 100% but Vicroads site should cover this).
See bold text for answers.
Hope it helps and good luck.
Cheers
Cheers
Thanks mate.
Just another quick question:
If I still need to obtain another RWC in VIC, the RWC in NSW is not really needed right? ---> was that what you meant in your answer to my first question?
cheers
Edited by meowdog
Thanks mate.
cheers
Yes, if you're going to register it in VIC, what is the point of getting NSW cos they're different (all state of Australia have different laws in Roadworthy).
Another reason to bargain the price down a bit.
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
    • Id like to race in the US i think alot of those track would suit me   For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
