^ Totally agree as usual Nik :D
The EPA laws for the most part are in many cases from 1992. Very out of touch with the real world as it stands today. However reforms simply won't come until the Gov't realise there is money in it.
As there most certainly is - do what WA do with the "mod permit" scheme. Each mod(s) require certs/permits as long as they are within reason.
Then charge money for such certs/inspections. Gov't would make a fk'en fortune and we could all drive legally on the streets (again, within reason) :)
Sadly it is the muppets that ruin it for everyone else. People putting blown/injected V8s into Cortinas case point number one. They just were not built to have 800hp motors in them and a LOT of people dodge the conversions up. Of course some do it right, but they are always a minority as it costs money to do a proper conversion mechanically.
Oh and many congrats btw mate :thumbsup:
Woohoo..coped my first defect in the Gtr after having my license for 3 weeks for being too low, it's only a minor. What ball park in price will I be looking at to get it raised, it has Olins coilovers
You're lucky. I got defected for height a week ago and they gave me a major so I needed RWC.
You would be looking at roughly $100 in labour to adjust suspension and then you should also consider a wheel alignment.
Do you know how much lower than legal it was? If it's not much you could get the mechanic to tuck the exhaust up a bit (by far the lowest point on mine when I got defected a few months back), bigger tyres will also help obviously if you're able to borrow them from somewhere.
If they look at the tyre placard then you won't pass with high profile tyres etc.
Sometimes they might, sometimes they might not.
Well hopefully they don't check. And Ric, the exhaust is the lowest point but it's low by quite abit exhaust tuck won't do much I reckon even though it's the lowest point
You can ask the suspension place to put some rubber spacers in. This may get you out of trouble and take care of some of the sag in the springs which occur over time.
Attending to the exhaust and raising it up slightly is a good idea.
Hrmm that sucks drove all the way to my house to borrow a C-spanner for nothing.
Not sure what you can do James because looking at your car your exhaust was very low
Either stock exhaust or stock suspension are my only ideas :(
the make it not hang so low? or if you want to get fancy they'll custom make the piping to go above shit, my one they made the hangers shorter i believe..
probably helped that i know them hence paying $50 but eh its really not that hard like your implying
Hmmm interesting.
Custom making piping is pretty expensive (definitely not $50), but I get where you are going with re making the hangars. That would cost your quoted $50, so you are spot on. Getting the hangers changed would work pretty well, so it's a good suggestion. :thumbsup:
exhaust tuck will 100% solve your problems you can get it basically flush against the under body costs fk all to tuck an exhaust
Flush under the body is going to melt $hit! you need at least 25mm (the requirement). Stainless sheet with air gaps are your friend.
I'm not implying it's hard. Hell, I made the whole stainless system on my 1600 including the dump (took me 4 days just for the dump mind you because I made it from scratch, but did get the flanges laser cut...)
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
