They will always get worse.
Hence build the car to be as legal as possible. And if not, reduce swap-over time.
In less than 60mins I can have my car legal. And even then it's hard to pick initially anyway.
Smart modding = win.
Does that hour include whatever is required to pass a full epa and full rwc?
It now would take me just over an hour to pass noise and rwc but passing a full epa would not be so easy.
I used to pass rwc, noise epa and full epa with 2871r turbo im my old s15, so as long as it mounts like standard turbo and looks similar, they dont pick on it.
I also passed full epa with PFC. Work that one out! Of course no hand controller.
  • 3 weeks later...
GDAY LADS
I got my R33 out of storage after 2 years.from what ive heard you cant have any induction mods now. I remember you used to be able to have either a pod filter or an FMIC im guessing its changed now.
Its the same as its always been, 1 mod.
got pulled over for having my fog lights on, then defected... be careful lads
Was there fog or low visibility (apart from being night)? if not its illegal to use them, always been that way, they are f**king annoying for oncoming drivers and barely more than wank factor for the car that has them.
GDAY LADS
where did you "hear" this from?
It's factually wrong.
It was raining, I find it easier to see the wet road with the fog lights on. But by the time I got pulled over (about 2 mins later) the rain had stopped. Personally I don't think they are bright enough to cause a distraction, but the law is the law. I got off lightly with the defect though.
Hey, my future track car (R33 GTST I bought form interstate a while back) has been taken back to standard. It now has RWC and I've booked it in to get the plates.
So, I book it in, and depending on VIN #, it determines the type of 'inspection' the vehicle gets. Of course, my car has to undergo the more expensive inspection (only $40) which makes me wonder - what does the inspection consists of? The Vic Roads lady gave me a nondescript answer (she was either dodging the answer or had no idea).
Will Vic Roads just check the engine/chassis #'s, or is it more strict? Are they going to go over it with a fine-tooth comb?
Anyone know?
They simply check the engine number.
That's all the "extra" inspection is. I got told when i re-rego'd the GTS-R that as it was a grey import, it was "high risk" and needed this inspection. Turned out to be essentially fvk all.
Good to hear.
Where's the engine number on the R33 GTST? 'Cos I know I'll need to show them where to look....
Never heard of having to pay extra for an inspection, no need to show them the number they have a book telling them where it should be.
Yep, paid it....
Last time I had to ring someone to find out where the engine number was - the woman inspector had no idea.
YAY! got rego on the car.... but the inspector made me sweat.
He said that most interstate cars don't have the compliance Chassis number stamped on the body, just on the plate. It just so happens my car had the chassis number stamped on the strut tower - otherwise I wouldn't be able to rego the car there and then!
  • 1 month later...
Quick question; recently got a letter in the mail for EPA (exhaust noise).
As for the actual procedure; book ($40.30, sigh... apparently going to go up $1 after July 01 lols) at an approved noise tester (list that came with the mail) and get the certificate of compliance for noise.
Then I have to physically hand this certificate in at the EPA in Carlton? Do I need to book for that if so?
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
