ill give them a shot anyone in particular i should talk too?
Speak to Shui or something like that, white guy with long grey/black hair (the owner). He wont pass obvious things like leaks and what not (obviously) but he will let HICAS lock bars and Coilovers slide.
sweet all my other stuf is sorted the only real issues are tint, coilovers,oil relo and soon to be hicas lockbar
+1.
Won't end well I'm guessing.
won't end well? its Sam by the way scotty
Yeh Hes not buying the car he's trying to put it in his name so it's not like he's getting ripped a new hole
What did i miss? whos ripping what? :blink:
  • 5 weeks later...
just wondering if anyone knows how camber wear is measured by the book?
say if both wear indicators are fine yet there is a tiny bit of camber wear ( 0.5 deg camber ),as most new tyres run off on an angle at the edges anyway
thanks
    • What ECU is on your car @silviaz? You can just change the idle target table yourself and the IACV duty cycle. Noting that if you play around with the screw you'll also need to revisit the idle base duty table as you will end up offsetting the lot. Another reason why DBW is superior, there's less mucking about.
    • Yep. Saw that on the image above but, wonder if it makes more sense to clean out the iacv because let's say in theory mine is dirty and if I clean it the rpm will drop. If I first go to my tuner to drop the rpm and then go to clean my iacv won't it drop further or is the rpm a fixed number?
    • Yeah it was a good result, and confirming the car is full of fluids and all interior etc in, other than fuel. I think a few pages back (maybe many pages!) he mentioned some serious lightening in the doors with the chassis punch, might have been done elsewhere I hadn't seen yet too
    • He still had the suspension dialled in for him! I would have sworn the lowest weight he ever got to was 1300kg though Maybe Neil had been drilling a LOT of holes somewhere you haven't found yet... 😛 Or has he also drained all the gearbox and diff oil out too, between it, and a tank full of fuel there's about 65kg to 70kg to add back in I'd guess. 😛
    • Yeah this isn't a super complex shape, but I was still happy to buy instead of fab version 1; very little in a modern can is a flat surface, and that is true here again - the undertray has about 50mm in height differences that I would have had to work out myself. I will probably make something more substantial before it does any rally, I don't think 1mm steel is too much use as a bash plate. There is also cooling to think about, Z1 have done a bit of development and have some air holes and louvers in the shape, will see how that works out too
