lol... you want past experience?
Wait until the officer drives off and then pull the defect sticker off right away OR as soon as you get home.
Then just sticky tape it on once it dries (or just wipe the glue off and tape it on). It's only illegal to not display it... Says nothing about taking it off and immediately re-affixing so it's not a massive pain in the ass later!
That's true experience for ya :merli:
Lol I did this, except in front of the cop, I had tape with me and he said its fine lol
Yeh went into hillside after finding it lol that moved back from burwood hwy. They can't fit me in soon is the problem. Email and rang EPA for extension but I just would rather get it cleared asap.
It's for an R33 GTST out of curiosity what difference does that make? different hangars or something for exhaust?
Edited by jukic.j
Hanger points are the same gtst to gtr. Only difficulty you may find is trying to fit a gtst specific exhaust onto a gtr because as we have found out trying to put my super drager onto grants R the curve of the rear section isn't designed to clear the subframe brace so it fouls against it.
I believe it's that hangers/points where it attaches that are different, but I could be wrong about this. I have a 33gtst full stock exhaust you could possibly borrow mate?
34/33 (non gtr) have the same 4 hanger points.
just some minor differences in the muffler and pipe itself.
Ah the Hume Camera's have been on since Aug, so probably caught speeding then come processing time - system realises it was suspended.
That is amusing failboat at it's best
Yup came with a speeding fine too. whatta fail
  • 4 weeks later...
now i've got question which i cant seem to get a straight answer for.
can i notch castor rod mounts ( think of s13 ones, they bolt up to the rad support and chassis rails under the engine bay) as in cut a section out and weld in a bit of thick angle or C channel to clear something ?
kinda like this
..........................\/..................| <----- side view
( couldn't center it with out the full stops)
called up some auto engineers off the vic roads site and cant get a straight answer and my rwc guy is away sick
thanks
Edited by Dan_J
lol Nik, love it - and i do agree given the "level of effort" factor. :thumbsup:
Slightly not so simple answer:
No - without VASS approval.
Conditional Yes - with VASS approval (Engineers Cert) - but you MUST talk to them BEFORE doing it to understand their requirements.
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
