Hey guys, my R34 GTT got a defect notice, fine, and need an RWC to clear all just because of a BOV.
The RWC guy wont pass my POD filter that's secured to the chassis, everything else including BOV he ignored. He said needs the airbox...
1) Does anyone have a spare, or can I borrow an airbox of someone with an R34 GTT for a few hours to get the RWC? (I can drive to you)
2) Will Vicroads check the stuff the cop wrote (BOV)? Or just look at the roadworthy and clear it?
You are allowed one intake modification.
IF:
-you have a factory intercooler then you do not need to put a factory airbox on.
-you do have an aftermarket intercooler, then he is right.
If it's the first line then tell him he is one of the many uneducated RWC mechanics in this world and go elsewhere or simply pull up the EPA documentation about modifications and show it to him.
And no, Vicroads don't check the car, most of the time they don't even know what they are looking at anyway. You just hand the RWC in over the counter (or post it in I believe, but safer to hand it in IMO).
Thanks for the reply, Its all stock intercooler etc. The entire mod list is just BOV + POD Filter.
Ill go see if he will accept the documents... probably won't... I might need to find another proper RWC person, as the guy above me said in dandenong-ish area...sigh.
He could be counting the BOV as an intake modification... I'd reinstall the stock one, they are perfectly good even on modified cars... and less attention from po-po-police
Yup, the car came from Japan with the BOV, I found a stock one recently and will be installing it soon.
He never said anything about the BOV so I'm not really sure... I guess I'll have to wait and see.
Apparently he's just a stubborn person, he didn't give a roadworthy on my old supra because the electric seat motor didn't work and he was too tall to fit inside...
  • 1 month later...
Hey everyone,
I've just been defected in the new year and i just want some clarification as I've never had one before.
Its a major defect, RWC as well, and needs to be cleared within 7 days oh and a fine of $369. :)
The copper took some photos (for evidence obviously) of the engine bay also on the "descriptions area" wrote;
  • Engine - To comply ADR 79 law. <-- what do i have to get done as i have a pod filter and inter cooler which i know i can only have one or the other. which i'll be putting the stock pod back on.
  • Exhaust - Excessive noise to be eliminated. (removed exhaust which i was going to get quite anyway)
  • Tail pipe - to be horizontal or downwards 25 degrees (see above)
  • Suspension - to retain 2/3 original height - lol
He didn't say what needs to be changed, just that my engine is supposed to look like it came out of the factory.
i believe it's not an EPA but just a normal defect and infringement notice.
Q. I have a GTX and a 4" intake, is there a way to get a pipe made to join onto the stock box, since it's 2inch? i cbf taking the turbo off... too much work
Could someone with knowledge shed some light on this please.
Cheers!
FYI: Also was gonna get booked for rear tint for being too dark (but didn't have the tint detector machine in car, apparently a law passed in 2011 saying all windows must be visible and at a certain %.
Edited by Skyline_034
Pretty sure it's 2/3 of original suspension travel, and minimum of 100mm...
Not 2/3 original height.
Cool, so swap exhaust, raise car up, stock airbox with a black reducer to the AFM (or are you running MAP?) if your piping is in the right area
you are correct, my bad, typo. "its To retain 2/3 original travel". <- so this means to raise up? wouldn't they just write "it's low" or something?
my AFM is after the turbo in the cooler line.
Nothing between pod and turbo besides 4" custom pipe.
Thanks for the speedy reply
the 4" pipe counts towards an intake modification, so does the pod, so does the intercooler, so does the relocated AFM
in other words that shouldn't pass roadworthy due to the above you have mentioned? in other words have to put stock turbo back on and relocate the AFM back to infront of the turbo?
Have been lurking for a while and this is my first post so apologies if it is in the wrong place. I owned a GT-R a few years ago when I lived in NZ and am keen to rejoin the club in Vic so have been reading this topic with interest and some dismay.
From what I have seen on Carsales etc, the vast majority of GT-Rs are modified in a way which would probably render them in violation of some law/rule/statute/whatever. E.g. coilovers, ECU, Pods + 1 other intake mod, exhaust that is 90+ but quieter than the bikes that I can hear outside every night. So is it the case that if John Q. Law "asks" you to pop the hood to take a gander and sees something that isn't factory beige, he salivates at the thought of dishing out the defect notice? Or is that overly cynical?
I would prefer to avoid this (obviously) but thinking back to my previous GT-R which had aftermarket turbos (the factory ceramics died a horrible death) it might be defected when the intent was to replace a broken item with something more reliable.
Or is it a case of "suck it up princess" if you want the toys and be prepared to swap parts back to factory as required?
Cheers
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
