Hi um i dunno if this helps but i had 3 1/2" catback then i gat the epa notice, so i had a good look at what i had under the car and found a Flange plate just under the the rear axel that had the cannon attatched, so i went to an exhaust place and got them to make the back bit out of 2 1/2" with a nice big quite muffler. It cost me 140 but at least they done what i wanted other places wanted me to replace the lot for 350!. Anyway the test showed a nice quiet 80 db.
I noticed that i had no power, no noise and no fun. so as soon as i passed the test i chucked the cannon back on all better now, and when i get another notice probably next week i already have the solution!
:D
i got tested at 100dB with my Trust Power Extreme Cat back, Blitz Front pipe, and Trust Dump... went down to the local exhaust shop and got a weasly bit of 2" from the rear flange with a fairly pissy round standard muffler and they re-tested it at 85dB! only cost about $120 and very suprisingly the car doesnt seem to of lost any noticable power!! however its quiter than a standard ford laser! :D
Also, aparently Silencer plugs WILL NOT PASS according to the EPA noise tester i went to! Mine only brought the noise down to 94dB anyway but the guy said even if they're welded in they're not allowed to pass them any more! :ninja:
Does the EPA actually get the car on a hoist or take it for a drive during a full emissions test??? (obviously this is different to getting a RWC)
yeah i the fmic isnt stock, i undersatnd you cant have both. i just thought it was wierd how quick he let me go, and i also thought that you got caneried when you got a epa???
they dont need to stick around long.... once they've got ur rego they already know where to send the letter!
probly just checking if the driver was also the owner! :D
This should be an easy one, but a quick question, if I buy a car with an epa on it and no rego in victoria, can I get a day permit to get it up to Canberra? or will I need to trailer it up? Car has an epa on it for excessive noise.
If the date on the notice has passed the cars rego will be suspended. That mean that in VIC you can;t get a day/unreg vehicle permit.
As all the state systems are hooked up now I would be almost certain you would not be able to get a permit to drive the car in the ACT. So you will have to trailer it up.
  • 3 weeks later...
Thanks for the info stolen_s15
It might be easier if I just post up the car's mods and if anyone can tell me which is defectable, apart from boost controller. Couldn't find any info on whether other items eg., turbo timer defectable.
HKS split dumps
HKS front pipe
HKS hipower catback (legal noise I think)
HKS adj cam gears (IN/EX)
HKS timing belt with Trust clear cover
Apexi pod air filter
Turbo timer
Nismo twin plate clutch (super coppermix)
Cheers. Much appreciated.
Clutch - No issues
Air pod - only okay if you dont have a front mount added on (GTR excepted)
Timing belt - No issues (cant see any problem with clear cover)
Catback - Legal if it meets both noise and emissions levels.
Others, no idea, but I think they are all okay.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
