so if you did get pulled over for being too low in a factory fezza... what happens then?
the law CLEARLY states that no point of any road driven vehicle can be below 100mm... (i have looked on the vic roads site and it does not say "except fezza's cos they are cool and hyperexpensive"
when i got defected last week EPA was there and they tested my exhaust and i was 9db over and i am going to make my exhaust and make it more quite and around the legal limit. but im running a PFC in my car and just to be on the safe side if they do an emmisons test im gonna install a stock ecu for the test but having a highflow turbo will it still give a different emissons reading even though its running a stock computer?
An f430 has 4.5 inches ground clearAnce which is like 11cm. I'm guessing it looks low cuz the body is prob the lowest point and not a hanging exhaust
yah, but they have other models too... i'm not sure of fezza dimentions tho...
and the exhaust is not always the lowest point in a car.... mine is a custom job and is all tucked away :)
I'm getting around to clearing my EPA that I got last august.
They only show 2 places for Emissions and noise. Hoppers and Moorabin.
Anyone know of closer to where I live in doncaster east? I heard there was one in McCloud but can't find it on their website.
I have to get an EPA noise and emissions test done fairly soon and was wondering If I could get some advice? I have a R33 gtr vspec series 3, current mods are, -5 turbos, power fc, greedy elec boost controller, nismo fuel pump, fuel pressure regulator and injectors, cam gears, exhaust, and pods
I was planning to remove the boost controller, return the injectors and ecu to stock. I believe that the turbos shouldnt be a problem as they are nearly the same as stock. Do I need to return the fuel pump and pressure regulator to stock, I know Im meant to but will they effect emissions if the stock ecu is controlling them and would the inspectors be able to tell between the stock and nismo items. I will quieten the exhaust and leave it that way. Also if I refit the stock ecu will I need to get the car retuned? And is there a difference between an ecu for a gtr and gtr vspec. Any advice is appreciated. Thanks.
I live in Greensborough and still had to go to Hoppers to get my full emissions test done. Was a major pain in the arse. Apparently the Macleod one doesn't to that kind of stuff, which sucks coz its like 10 mins away from me.
Mcloud do that sort of stuff. They only send you there when you have had prior EPA issues. I've been to 2 noise test and a full emissions test in moorabbin. Then got another EPA and they said I must go to mcloud. Which is better because they don't have a hoist :P
Did you explain the situation?
Just said that McCleod would be a lot easier since I will be towing it there and they said that those 2 places are the only ones I can go to.
Typical Government Agency. Everything is just too hard for them.
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
