There is no tolerance far as i know however. If it's 0.5dB over, you are over and will fail. As the EPA people "tell" you, thier meters are perfectly calibrated.
I know for a fact they are not (having gone to two testers and had a variance of 2dB), but thats just how it goes really.
I failed at 92db with a stock cat back exhaust. Front pipe was aftermarket. Went back with new rear muffler and it was 84db.
Just a heads up if going for a noise test.
What the guy at the exhaust place told me (they do epa tests too) is to run your car for at least 5 mins to get the cat converter hot. He reckons when it's hot it is about 2db quieter.
Wouldn't be the first time a car has failed in that exact scenario Russ - same happens for GTR's with aftermarket from pipes & factory cat-back.
Simply cannot get them to pass.
I'm guessing you went back there with a super-poo-shooter rear muffler? :cool:
pretty much. Just wanted the quietest cheapest muffler they had. cost me $140 and used it for all of 10 mins...
If I'd known about the cat temp thing it may have just passed and saved me 140. Although I wasn't going to tow it all the way down there to find that he'll fail me again for 90.1 db.
:cool:
Hey guys, about to do some work to my car and im wondering if what im about to do is going to cause me much issues.... i know the car does regardless and the 2 times ive been pulld over they go straight to the turbo and start looking in my passanger seat/door trim for things.. im guessing a boost controller...
Anyways if yas can just make some suggestions or if you think i will be fairly good with what im going to do let me know (peace of mind :P ), from what i can tell i should be ok.
Also whats the deal if i have to goto the epa or something? can my tuner tune the engine to run fine or is it just a matter of put the stock parts back on :S?
im new to the skyline/performance scene so yeah any help is appreciated. thanks!
also im in melb vic.
R34 GT-T 1998 White.. Manual Coupe - Daily to and from work driver/Weekend cruiser.
Currently: Stock as a rock (side skirts/Turbo timer)
Pulled over: Twice... car was checked over thoroughly both times... number plate noted the first time.
About to put in:
Bosch 040 Fuel pump
Sports Panel Filter
Turbosmart boost tee bleeder (will ask installer to hide it best as can)
Stealth FMIC cooler kit (contact has provided the cooler as he suggests is best for my car and is completely legal/no cutting etc)
Splitfire Coilpacks
Dump/Higher flow cat/Custom made twin rear with large twin stainless tip - High ride to give it the best stock look.
General service with platnum spark plugs
Nistune Chip
Exedy HD Clutch
Two issues...
1. The boost controller in that list you have.
That is easy to hide, or even remove for the sake of going down to the EPA. Would take 10mins if that...
You could also get an upgraded actuator as another idea. So permanently run 10psi, and then don't even have to worry about a bleed valve being there. No chance you'll get pinned for a aftermarket actuator, virtually impossible to tell something like that. Just rub some oil/dirt onto it before you install it if you are really worried. ;)
2. Exhaust. No way with one muffler it'll be legal. At a stab i'd say around 93-96dB, you'll need another muffler after the CAT (before the diff) to get the noise down to legal.
Everything else will be ok.
Awesome thanks for the help people!
Im happy with my boost tee but thanks for the acuator tip (i have nfi what it is ;)) so yeah ill ask the installer to hide it and paint it black :devil:
Yeah the exhaust i think will be the hardest part its also 3" so im guessing when i have to get it tested ill put the stock one back on.
Should be coverd then im guessing...?
thanks for the reply guys :)
was talking to a guy who ran an exhaust shop, he claims that a car only needs to follow sound restrictions according to the year they were released. So while recent cars must be under 90db, if the car was released during the 95db limit, that's all that's required.
any truth to this?
Totally depends on the year of being made.
As you said Alex - pre 1983 cars have different rules, there are also cars that do not require CAT convertors and so on due to age etc etc.
HOWEVER should you put say a RB26 into a Datto 180b - you would need to comply with the MOTOR's emission requirements, not the cars.
It's very much subjective to the situation - if you can provide more detailed info we could help futher :)
yeah the GF's 1973 1200 had to get a test, went in with one muffler and reading 110db, bolted on another one and it went under the 96db limit woot! It's loud again now lol
I know that most people around here who have the later model Datsuns have to comply with the stricter noise and pollutions ADRs pretty sure the cutoff was around 1983
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
