Hi Guys. I am also new to the skyline/turbo scene and this is what has happened to me.
I have a 1995 GTS-T. I bought the car with a roady and reg 2 weeks ago and yesterday I got pulled over and fined for driving an unroadworthy vehicle $300. (Steering wheel, Two intake mods, and apparently the exhaust is too low but the car is standard height)
I'm in the process of contacting the mechanic who issued the roadworthy as I now have quite an expense infront of me due to him not doing his job properly.
Any tips on how I should go about this??
Also can you get an aftermarket steering wheel that complies as I really dont like the stock one.
Any help much appreciated
Thanks
your car came factory with an airbag so any wheel u replace it with must retain an airbag so in short no keep your stock one.
as for the exhaust if it is to low which sounds strange if ur rocking tractor hieght but get it tucked will cost u fk all.
put ur factory airbox back on and be done with it. and just put it down to modified car tax.
your mechanic is worth arguiing with only if the car is exactly the same as it was when he issued a rwc, if not your wasting your breath.
good luck
oh and welcome to owning an import in victoria :D
Yeah the car is exactly the same. I've only had it 2 weeks and its spend more than a week parked at the airport lol.
I wouldn't mind changing things back but I have none of the stock parts. It's gonna cost me a few hundred bucks to get something that really I should already have.
Oh well. Think I will take it up with the mechanic and try to get something out of it. Can't hurt I suppose
stock airbox is for sale right now in someguys thread for $100 to tuck ur exhaust IF u need to measure yourself need 100mm + and steering wheel try deer park wreckers or similar. i rkn you can do the whole lot for $250-$300 tops.. and once its done its done..
i feel ya pain with having a rwc an all that but i just also know your chances.
good luck anyway
Im fitting a new front bar atm and its the explosion kit so it retains the stock lights with the indicator and fog light at the bottom, now Im having trouble fitting the lights because the fog light side fouls witht he intercooler piping so I was wondering if I take out the fog light at the back and only keep the plastic in the front so It looks like there is a fog light now just wondering if it goes to a roadworthy check and they try to turn on the fog light and it doenst work because there not there anymore will that be counted as not pass?
if its there then it would be epected to work the likelyhood of getting done would be slim and you can always say the globe died or whatever the case may be, can you trim the back of the light or whatever it is thats hitting the piping to get it in there?
yeah im gona try and trim back the back of the light but dont know if it will be enough if not then yeah just gone have the fog plastic as a dummy with no actual light in the back and just leave the indicators
can someone clear up whether the 100mm ground clearance rule still applies? it has been removed from ADR 43 in 2007 (see link below, section 6.4 ground clearance) and there is now a new way of calculating the ride height based on distance between axles or something.
http://www.comlaw.gov.au/ComLaw/Legislatio...ation1FINAL.pdf
if an ADR is updated does it apply to cars that were built (or complianced for imports) before or do we still use the old ADR's?
also wondering how this new rule will be policed by TMU/vicroads since they now have to calculate the minimum ride height for the car. I worked out that for my wheelbase (2.570m) the ground clearance needs to be at least 86mm. shorter wheelbase cars can go lower.
Sandeep,
It says in the new ADR that all previous ones concerning the same topic have been repealed.
The Acts Interpretation Act 1901 says - "the repeal shall not affect any right privilege obligation or liability acquired accrued or incurred under any Act so repealed".
So it would seem that the old laws are now null and void. So you're on your own figuring out the new formula :woot:
EDIT (forget the above lol)
the ones that are repealed are all ADRs entitled 43/04, so all latest editions of 43/00, 43/01, 43/02 and 43/03 are all still in effect.
the link you posted (43/04) applies only to vehicles manufactured on or after January 1, 1998 (see the applicability table, s 3.2), the other rules (/03 etc) apply to cars manufactured on different dates. it seems as though if you have a car made after 1998 you can get away with epic low front bars (assuming your suspension is done in accordance with Vicroads VSI8)
i don't know when your car was made, but check the rules to see which one applies to you.
for me personally, the /03 one applies (built on or after Jan 1, 1994) so the requirements are:
for any point in the width of the vehicle which is within one metre fore
and aft of any ‘Axle’, 100 mm;
for the mid-point between any 2 consecutive ‘Axles’, the dimension in
millimetres obtained by multiplying the distance between those 2 ‘Axles’
in metres by 33.33; and
for any other point, ‘Ground Clearance’ is such that if the wheels of one
‘Axle’ are on one plane and the wheels on the next consecutive ‘Axle’ are
on another plane which intersects the first so that the angle between them
is 7 degrees 38 minutes the point will pass over the apex transverse to the
vehicle formed by that intersection
It's always been axle's in relation to ride height...
However people just simplistically said "100mm" as it's easier and in most cases the lowest point is the CAT &/or rear underpass for the muffler...
So it's always going to be right near axle's anyway and not the middle of the car :D
(this is an example only)
You could have the exhaust hang say 90mm right in the middle of the car, but then soon as you get near the rear axle/diff you end up pushing outside.
So when making an exhaust you wouldn't deliberately drop to 90mm in the middle, just keep it 100mm all the way. Lesss effort.
(this was an example only)
:woot:
I'll have a more detailed look @ it all later, don't have time from work ATM.
car is a '90 model so 43/01 is the ADR for my car, but it was complianced in 2005 if that makes a difference.
43/01 also says 100mm for any point 1m from the axles (so since the wheelbase of the zed is 2.57 metres then the 0.57m in the middle of the axles can legally be 86mm like R31Nismoid said).
Ye - but why would you bother? No point deliberately making an exhaust like this:
tuck up -- bend -- hang lower (50cm) -- bend -- tuck up again
Would cost you more. So yes you can be lower than 100mm, but what's the point when its only for 50cm? :thumbsup:
Better off just going 100mm all the way and then not even getting into the argument over a defect.
yeah my car is above legal height anyway and don't plan on lowering it anymore since it'll most likely handle worse if I do. exhaust was done last year and is all tucked in above 100mm, was just trying to explain the law just incase other people have cats or resonators that hang abit lower in the centre of the car.
I doubt they will though.
CAT's have to be a certain distance from the front, and that is always close to the front axle.
Same with mufflers. Usually you can't get big ones in until after the transmission is passed and where the driveshaft begins and that is fast approaching the rear axles on most cars :(
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
