hrrmm we got an EPA notice for noise for the 32 as well.. I wouldn't have thought it was that loud personally but maybe I'm just going deaf from something else..
It has an XForce turboback exhaust on it. Anyone else have one of these on a 32 gtst? Wondering whether it will pass without having to swap it back. Tester said no on the phone (in relation to ANY a/market exhaust) but I don't know.. doesn't seem that loud to me??
God they are annoying. Apparently drove past a cop on Flinders St. I think they're just fishing caus they couldn't pull me over at the time. Pain in the butt tho, don't really have time to stuff around with this crap, so over it! I'd really prefer to just give them the $40 and be on my way...
Well what will they do. Send me a EPA in the mail and a defect anyways. I can't see what they can legally get you for. They can arrest you but do you think they will for that?
epa letter is far better cuz you don't get the fines since when you go for the test, the car will be magically stock.
i was thinking hidden kill switch, when im told to move the car, it wont start. call a tow truck and go home :P
Can I just say thanks for posting up this thread. Just had my pod filter/intercooler queries answered. I love you guys :D
Can I just say:
THANK YOU FOR READING THE WHOLE THREAD and not asking the same question over and over again!!!!! :miner:
herald sun article announcing operation Clear Vision started today in the CBD concentrating on defective vehicles, and especially those with illegal tint. So be aware, avoid Carlton and CBD.
http://www.heraldsun.com.au/news/victoria/...x-1225885515333
media template:
[modification] is being blamed for increase crash risk
follow by an article with no statistics or facts of any kind to proved such claims.
Edited by Peter89
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
