I want to do the DE+T conversion, personal choice that's all. The idea of a turbo top end, but still keeping the N/A responsiveness and power appeals to me, and this particular car has a sort of sentimental value to me. Why does the majority jump to the conclusion of "engine out" or "new car" whenever there's a whisper of a DE+T? Do they post on holden forums about how everyone should fit a GEN III or buy an SS when they want to supercharge a 6? No...
R31 Nismoid, illegal as in because it's not an identical set-up to the DET? Thanks for the reply btw. :D
many reasons the simple fact is because its the smart thing to do, its easier, cheaper and you get a significantly better car as nismoid said are you going to upgrade everything else as well or just wack a turbo on and hope for the best?
nobody is having a go at you we are giving you the best advice and trying to save you a lot of money and wasted time.
And if you do a de+t are you going to upgrade everything else to turbo? Brakes, diff? Can add up. Not to mention you can't run much boost through em or you will blow em up. So easiest way is to sell it and buy a turbo
If you get an engineers cert, and your exhaust is legal - then you can still be "reported" for a "check".
Its not a case of being proven guilty. You are guilty by default in this state.
thanks nismoid and i think its most countries government has the same rule bout being guilty...
Guilty till proven innocent!
ok so times comin up for me to be of my p plates so thinkin sellin my na n buying a gtst
got a few questions
1. intercoolers, where are the factory holes located so i can tell if they have cut a hole that wasnt standard becuse the extra holes make car unroadworthy correct? and yes i know only legal with factory airbox.
2. been lookin at a gtst on carsales its pretty much all stock but got a Garret turbo in it, now this turbo is not standard can u get pined for this?
3. some on sale have boost controlers/Turbo Timers, i know this is an illegal mod, how easy would it be to remove it etc, or would i be better of asking the seller to remove it before i buy?
thanks for the help in advance Jason
OK I am one of those guys who couldn't believe that you could fail an EPA test with a stock exhaust.
BIGGG mistake.
Anyways found a place around the corner from the Morrabbin EPA tester.
I have an R32 GTR and these guys helped me pass.
TRUFIT Exhausts
435 Warrigal Road
Moorabbin
Speak to Gary. Nice guy. No I do not work for him.
got a few questions
1. look for a hole in thebody under the washer bottle if it has that try and avoid it the hole require engineers cert which is a pain in the azz u can get it welded up etc and swap to turn flow hopefully cops then wont notice it since they dont need to look there.
2. if its in standard position and not some big fk off top mount its highly unlikely you'l get done for it
3. easy as to remove but if u can get the car to come with a rwc make ur life a lot easier.
lemme know if you got more q's bro :D
thanks alex
yer i want to avoid the hassel etc so wanna make sure everythings ligit b4 i swap cars etc
yer deffs get buyer to sell with roadworthy for my peace of mind
and also remember i live in knox area lol hence the reason im taking the extra caution with what i buy and what mods it has to start with.
Has anyone had any experience about VASS engineering certificates? Doing some research.
Have heard heresay about them only lasting 30 days, but the only info I can find is that Vicroads will only accept them if they are less than 30 days old! No mention of them expiring once Vicroads has received the VASS cert. he more direct info the better, no BS hearsay about the rules.
Thank you <3
the problem with the certificate is the car is approved as per that cert at the time its issued, the police will be likely to say yes but that was issued on X date you MAY have made changes to the car since then hence defect.
is that what your asking about? or you mean engineers for holes in chassis?
nah talking about engineering the car for the modifications it has on it. Does the certificate state what exactly has been approved and tested? Or is it just a generic cert saying car is certified. If someone was going down the path of engineering, they would have put all the mods on first and then spent the money, so i think its a bit uncommon to upgrade after all the time/effort has been spent to get the cert?
Wondering if anyone has engineered modifications for their car in victoria.
^ Depends what you pay for.
If you want it all listed and so on, it all needs to be checked/tested.
My VASS was around $600 that was just for a motor swap & brake test (bare minimum). This was also because the car was VASS'd 7 years earlier.
Things are listed down, you'll just need them looked at which id imagine would add a little to the cost.
They are only valid for 28-30 days or whatever in which time you need to submit to VicRoads.
There after it would also them mean it's free game in the eyes of the Law.
No such "rule" they expire, given they go on your file. However as Alex said, nothing to stop officers claming you changed something.
You'd have to go through the court B/S to prove em wrong and so on.
If you have the time, then great, but not everyone does.
My Pulsar has a VASS certificate. I required it to change the engine number after an SR20DET conversion as the engine was never an option for the car. They check engine mounts, intake system, emissions, noise, height, brakes (including a drive test with brake test) to ensure everything is safe and complies with the relevent ADR's for the year the car was manufactured.
It cannot stop you getting defected for other modifications that aren't checked, legal and listed on your certificate. You have 30 Days to submit the form to Vicroads if you have been asked to do so - in my case so I could legally register my car with the engine it had in it. I hadn't been defected, it was just a precautionary measure because there was far more on the car I didn't want an officer to look at should he realise my engine number didn't match my registration. Just a bit of piece of mind. The certificate doesn't expire as such. I'm sure if an officer was being picky your engineer can re-issue the certificate provided no changes have been made.
My certificate was $750
Thanks all for the tips. Im mainly interested in getting larger injectors. However this would involve an ecu map to handle the larger injectors, and under the EPA guidelines is acceptable as long as it cant be re-programed and meets ADR. (Replace eprom chip in ecu)
So regarding the above, im assuming the engineering process would involve a full emission testing which would be the same process for a large turbo and exhaust? So that would mean all mods could be emission tested at same time?
Any information regarding full emission certification would be greatly appreciated.
Also what are the engineering laws about increased power vs braking? Usually with an engine conversion you upgrade to the brakes off the car the engine came from? So how would it work with just increase in power? Is there some ratio which needs to be met etc?
Thanks
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
