Got my roadworthy today. Much better than previous place, just had to change the tint on the front windows and get rid of the pfc controller.
Where did you get it done?? Or has anybody got a place that is slightly lenient on us??
heres an interesting question
the car i purchased came with a roady (was less than 30 days ago)
Over the past week ive noticed that there has been an oil leak or two off the bottom of the engine. the main leak is coming from the sump plug hole. Replaced the sump plug in the hope that it was the problem, but it still seams to be leaking. there also seems to be another oil leak, but im unsure where it is.
now here is the question lol
isnt the roady supposed to pick up on such things as oil leaks?
if this is the fact, is there recourse against the shop that issued the roadworthy to fix these problems because they missed them/overlooked such issues?
cheers
They are not meant to sign of a rwc if car has oil leaks...a rwc is valid for 30 days from date issued...if I were you id take the car with the cert back before the 30 days is up, you might have a good chance to get it fixed free of charge.
thats what i thought.
however im not a fan of good chances, id rather a full chance
A leak can develop after the RWC is supplied.
You'd have to prove beyond reasonable doube it was there when the cert was signed.
thats what i was worried about.
would the oil/grime caked onto the sump prove?
any other way i could prove it?
From what ive always thought, a rwc check doesnt actually fix any problems if they arise, they only note them down. So if you go in there with leaks they might cancel the certificate and get you to fix them (at your cost) before they will certify it again.
Davey32 you have a PM.
lol
don't like your chances unfortunately, cant hurt to ask but they will be on the defence straight off since your basically saying to them they are in the wrong.. often doesnt go down well
Problem is unless you take a photo of anything wrong straight after buying the car they will just say 'oh that happened after', i'm not talking about really bad stuff like cracked screen or bald tyres, but things like oil leaks or whatever they can be cleaned of for the roady and then start leaking after a few days, no way you can prove otherwise.
i got epa'd, stupid thing is, when they said I was "spotted", I was at work, and my car in the work parking. i didnt even drive through the place.
I've had it cleared but wtf are these idiots doing.
same thing happened to me, apparently i was driving on a monday night at 12am about 2 weeks before i was heading overseas
thing is i was asleep because we were busy trying to finish off as much work as possible before i left
problem is you cant contest it because they will still say test the car and prove its not to loud etc
Couldn't you contest it with a factory exhaust? Assuming of course it was on at the time.
they would still ask for you to test it though, thats the thing... there is no point in contesting
at the time i had my old exhaust on anyway, a lot louder than whats on now but thats not the point
i was stung even when i wasnt driving :(
That's gay that you can get your car epa'd when parked.
Though I woulda thought the wagon would of been safe :ninja:
It is generally safe but we are in Vic, if it's anything to up their commission theyll do it, I remember on my p's driving dads falcon which is stock as a rock. And he got epa'd for the time I was driving. If they can they will. Oh and my car wasn't on ferntree gully rd like they said it was parked in undercover secure parking at work in the cbd
can you prove it was parked in the cbd at the time of EPA?
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
